Question about Gateway M-6866 15.4" Widescreen Laptop Blue PC Notebook
Computer freezes way too often
I sent my laptop to have it serviced because i. it used to freeze randomly when using the internet, using word or any other program ii. the system filechecker found corrupt files it could not fix. Using the full factory recovery option did not help.
All they did is reload the OS. NOTHING ELSE. Now, I get it back and here is the result:
i. the laptop STILL freezes ii. the system filechecker STILL finds corrupt files it cannot fix.
Most annoyingly, many other customers are complaining about the same problem on the internet.... So this is not just me. Any suggestions? Gateway wants me to send the laptop back again - I will do it but after the surprising service I got the first time I am skeptic about their service
  • 36 Answers
If you are still having file corruption problems after a full restore, i am willing to bed you have a bad hard drive. it's possible you can repair the corrupted sectors with chkdisk, but you will mostly likely have to have a new hard drive put in.
hope this helps
Posted on Jan 16, 2009
Lenovo freeze
  • if you have a driver issue then just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
  • And if you don't have a driver issue then download RegInOut that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors
Thanks
Jun 03, 2013 | Computers & Internet
Compaq Presario v2000 freezes
If your laptop freezes randomly follow the steps given below:
  • Disable Unnecessary Services
  • Run Disk Checkup
  • Disable Startup Programs
  • Clean Registry Errors
You can also get more help from this article:
http://www.backspacetab.com/laptop-freezes-randomly-tips-to-fix-this-problem-for-good/
Dec 08, 2011 | HP Compaq Presario V2000 Notebook
Very slow, freezes, jams, and is non responsive, I have to take battery out and wait for a an hour before putting battery in laptop, my computer is an acer 2350 travelmate, also when I bought this in...
This sounds like either a hard drive problem, when you power on the laptop there should be an option to enter BIOS or Setup (usually F2) once inside of the BIOS you should be able to run a diagnostic. and that will tell you if there is anything wrong with the hardware. If everything passes that test. you may have some serious Virus problems.
May 04, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
My Dell Inspiron 1525 freezes randomly after starting up. I can't use the mouse or keys to change the screen. The computer freezes around 5 minutes after starting up. I booted up in safe mode and have...
If you had no issue in safe mode the only thing I've seen like that is a virus that cuts of your use of I/O ports. boot into safe mode and try doing a system restore to a time before this problem occurred. IF that doesn't solve the problem try doing a clean install of the OS
Feb 28, 2011 | Dell Inspiron 1525 Notebook
My laptop will just randomly turn off...it will run well for a few minutes and then just turn off and everytime i try to start it over it turns off even quicker...within a minute or two...i realy need help...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Nov 02, 2010 | Acer Aspire 5315 Notebook
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
Froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
Gateway M-6866 15.4" Widescreen Laptop Blue PC Notebook Logo
146 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
