Hi, this is a netgear page on port forwarding:
http://kbserver.netgear.com/kb_web_files/n101145.asp
If you are gaming with an XBox, here is a page with instructions for your router:
http://www.xboxlivetheguide.co.uk/XBoxLiveTheGuide3.php?title=My%20NAT%20Setting%20is%20Strict/Moderate%20what%20can%20I%20do
If its the new one you have to configure it by opening the router by connecting to physically with your system with lan cable. eg. default ip of company is 192.168.1.1 than type in browser http://192.168.1.1 and than configure as per your requirement and than you the if range of the same subnet. For any further qurey feel free to contact.
SOURCE: nat settings on netgear wgr614 wireless router
there is no UPNP setting, just make sure it's enabled in nthe router settings and then the router will open the ports required for the Xbox automatically, normally port 3074 UDP
SOURCE: Strict NAT
Here is what I believe the correct solutions are:
1. You can set the xbox with a assigned IP and place it in the DMZ for the router.
2. Or you can edit the port forwarding on your router. There are notes on the xbox live forum. In short. port 3074 TCP & UDP forwarded to your xbox IP address.
Rerun your Xbox network tests and see if you get the OPEN instead of STRICT. This will resolve any Xbox Live connection issues.
SOURCE: Connecting a netgear wireless router to a 2wire
Are the router addresses assigned on the same subnet?
many routers have a base address of 192.168.0.1 and a subnet mask of 255.255.255.0 meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as 192.169.0.1 with a subnet mask of 255.255.255.0 his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say 192.168.2.1 with a subnet mask of 255.255.255.0 his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as 192.168.0.1 the second where the WAN is not used could become 192.168.0.2 (where that address is not in the active DHCP server's assignment range) or 192.168.2.0 (note the DHCP server had better be off or else the empty wan port 192.168.2.0 could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
SOURCE: set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
SOURCE: How do i change my router's nat type 3 to nat type
Instead of changing the NAT type, it is effective to forward ports on the router for your PS3. Perform the steps as mentioned in the below link:
http://www.portforward.com/english/routers/port_forwarding/Netgear/WPN824/PlayStation_Network.htm
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
