Question about Refrigerators
Product  Fridgiaire Refrigerator Model GLHS238ZDSA MFG in 2005 When the ice maker turns on to fill the water comes out of the water dispenser.
  • 1 more comment
  • rrsanders Jan 16, 2009
    Thank you, We will check the wiring to the valve and will let you know if this solves the problem.
    Robin in Texas
  • rrsanders Jan 19, 2009
    The problem turned out to be a burned out diode that controls the valve to the icemaker and the water dispenser.  Your suggestion was very close to the problem.  Thank you very  much
    You are very welcome and thanks for your help
    Robin in Texas
  • 61 Answers
Your water lines on the water valve may be croccer or the the wires on the valve are crossed has the valve been replaced latly if so change the wires on the valve around if not you have a shorted wire in the wireing
Posted on Jan 16, 2009
  • Shawn Smith Jan 19, 2009
    not a problem i was glad to be of some assitantce not all refg. have that diode on the water valve even not all Frigidaire refg. have thev so I have a tendasey to forget about it glad to hear you got it repaired .
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    My Amana bottom freezer refrigerator BB120TPW is 11 years old. The ice maker doen't make any ice. I can hear a noice coming from the unit, but no ice. I turned off the water and unpluged it. If it...
    Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
    You can get required parts from sears part direct online site or from repairclinic.com site.
    This will help. Thanks. Helpmech.
    May 29, 2011 | Amana Refrigerators
    I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
    HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
    Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
    Maytag sidebyside MSD2758DRW ice maker won't make ice
    If the ice maker no longer make ice, check the following.
    Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
    On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
    Check your door seals and thermostat, repair/replace as necessary.
    Thanks
    Jul 10, 2010 | Maytag Refrigerators
    Gss20I eph ice maker ?? If I turn the switch of
    I am almost sure the model ice maker for your refrigerator is Click Here=> WR30X10093 and the model number for your refrigerator is GSS20IEPHWW or SS for Stainless. It sounds as if a bad connection on the ice fill arm. The truth is they are electronic and made in China along with most of the parts on your GE. I replaced mine that was the mechanical type with this same model number WR30X10093 and the mechanical lasted 15 years. If you manually can make it work one time and fills properly but after one cycle yet turns itself off my focus is on the ice maker. If you want to check OHM's to the dual water control valves they should both be about the same. Applying 120 volts to each side of the coils being water dispenser side and ice maker side will or should open them. But you just said that moving the arm that it will fill one time so I am back to the ice maker again. If water control valve for ice maker side did not work you would not be able to do that. Sea Breeze
    May 20, 2010 | GE GSS20IEP Side by Side Refrigerator
    Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
    Good day,
    If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
    After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
    Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
    Dec 21, 2009 | Refrigerators
    Brand new ice maker, water fill to tray will not shut off
    The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
    Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
    Kenmore coldspot top freezer auto ice maker, water
    Dear customer,
                   We suggest u to perform the following checks to solve ur problem...
    1. Check the refrigerator for level
    2. Check the ice maker for level
    3. Inspect the fill cup alignment
    4. Inspect the water supply line
    5. Test the water inlet switch
    6. Test the water inlet valve
    7. Check the shutoff arm
    8. Test the shutoff switch
    thank you..
    Apr 08, 2009 | Kenmore Refrigerators
    Ice maker freezing up
    If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
    Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
    Refrigerators Logo
    76 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
