Question about Husqvarna Viking 1
Viking 190 sewing machine stuck on backstitch
My Viking 190 sewing machine is stuck on backstitch. We opened it up and the mechanical parts all appear to be functioning properly, so it must be somewhere in the electrical/computer? The machine worked fine 6 months ago, then put it in the closet. Pulled it out for some mending and it won't sew forward--only backstitch.
  • 1 more comment
  • Ldecorinteri Jan 24, 2009
    Machine would not go into reverse. Turned machine upside-down and now it is stuck in reverse and won't go foreward. Need explosive parts manual.
    Respond to Ldecorinteriors@comcast.net.
    Thanks...
  • Anonymous Feb 24, 2009
    Is this a good machine found it for sale $25 with no electrical cord? What do you think
  • Anonymous Mar 27, 2014
    I've downloaded the update and unzipped it on my desktop as required, it appears on my USB stick after I run the update, but once I plug it into the sewing machine it doesn't recognize the file, so nothing happens.
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
  • AApilot Sep 13, 2009
    Two reasons the machine won’t go into reverse:
    A: the machine is “Gummed-up” from old grease and oil.
    B: The return spring is WEAK.
    See attached photo.
    The red arrow points to a spring that is weak. Replace it with a new spring from the hardware store. (Technically, I replaced the spring with a stronger spring ($.69) than the original equipment spring, works great!)
    The area behind the blue arrow is where a cam reverses the sewing machine. Press the reverse button several times and you will see which parts move. Clean and re-lubricate these items.
    This is where the machine is most likely “gummed-up”. Over the years the oils and greases gel. Being that sewing machines are intricate light duty vessels, the gelling of the oils and greases make it hard for the machine to operate correctly.
    Procedure:
    Buy an electrical degreaser (spray can) with straw sprayer from an automotive store ($6.50). I turned my machine “upside-down” and cleaned it with an electrical degreaser. (Turn upside-down because the sprayed electrical degreaser will drip and run onto parts that you don’t want to degrease.) Only spray the moving cam behind the blue arrow. Use the straw extender that is provided with the degreaser can to perform this procedure. This is because you only want to degrease the reverse mechanism and not other parts. Re-lubricate with “sewing machine oil” ONLY! This is important as the viscosity of this oil is correct for sewing machines. (oil $6.50)
    Total cost is less than $15.oo to fix.
    I can supply you with additional pictures if needed.
  • AApilot Dec 02, 2009
    Get a spring that has hooks on both ends. If unavailable, cut new spring to desired length and use needle nose pliers to form your own hook on one end. The new spring doesn’t have to be exactly the same diameter as the old spring. The most important aspect of the new spring is the length and elasticity.
Pfaff 1221 sewing machine stuck in reverse
if you can take the pfaff back and tell them what its doing and have them fix it or get another sewing machine..
Sep 06, 2013 | PfaFF Sewing Machines
Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Jimmy
Dec 13, 2011 | Singer 4423 Sewing Machine
I have viking 1, my bobbin is stuck and will not
take out the parts in the bobbin area, you must have treads all tangled in there, and clean out all the lint.
May 16, 2010 | Husqvarna Viking 1
\i have a viking 190 sewing machine..it was put
throw the machine away I had a riccar machine I had to throw away for the same reason I bought it used in 1983 and could not get it parts it needed
Dec 13, 2009 | Husqvarna Sewing Machines
How do I open my viking 105 sewing machine to check inside. only thing I can find that opens is the plate under feed-dog
The rear cover has a screw at the top. Remove that and lift up on the rear cover as you gently pry it outward at the top and it will come off.
Nov 01, 2009 | Husqvarna Viking 1
Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Jul 14, 2009 | Husqvarna Viking 1
Sewing Machines Logo
1,968 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
