Question about Black & Decker D2020 Iron
My digital advantage D2020 won't heat up
I have a black and decker digital advantage D2020 and when I plugged it in everything works but the heat. Help please.
  • motoxmom617 Apr 16, 2009
    I am having the same problem everything is on but no heat. I really love this iron. Help!!
SOURCE: The Clean light on my Black & Decker Digital
I found a previous answer on FixTa.com that had a link to the owners manual for my iron. The info I needed was there and my problem is resolved!
Posted on Jan 13, 2010
Testimonial: "Exactly what I needed..."
SOURCE: Good morning, My iron black & decker d2020
The Thermostat has gone faulty. This can be replaced if you can get the parts. You need to contact, B&D indicate your problem, and exact, make and model, and inquire as to where you can purchase the parts, or if you do not wish to do it yourself, where to send it for repair.
Posted on Apr 19, 2010
heatman101
  • 43501 Answers
SOURCE: Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
  • 10 Answers
SOURCE: instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
Posted on Aug 02, 2010
SOURCE: I have a Black and
Fill the Iron with with 50% vinegar and 50% water and then soak 24 hrs water but keep the water level below the max line. Plug in the iron and set the temp to six and stand your iron on the heel and allow to heat for three min. Now unplug the iron and take it to a sink. Move and hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out. When finished release the steam dial plug in the iron and heat for about three mins to dry out the remaining water and unplug.
Posted on Oct 04, 2010
The steam wheel on black and decker digital advantage is stuck in the no steam position
This problem developed with our iron within the last week. Playing around with it today, I discovered that the dial WOULD respond to "persuasion". I forced it, and it cooperated. Find somebody with a stronger grip and try it.
Aug 03, 2013 | Black & Decker D2020 Iron
My Black & Decker d2020 iron immediately goes to auto shut off and will not stay on.
test the 1) fuse heat and replace it
2) test the board if there are voltage , if there are the board can be faulty or repair.
3) see your instruc. manual go to the section troubleshooting and see what is wrong.
God bless you
Sep 30, 2012 | Black & Decker D2020 Iron
Lights are on but not heatingup
Here is a tip that I wrote about Electric Irons and why they do not heat....
heatman101
Jan 14, 2011 | Black & Decker D2020 Iron
Iron Blck & Decker: model D2020. I would like to clean my iron because is stared to stain all my clothes. I just open the white plastic parte on the back, but i dont see any other screws or how to get...
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
Jul 18, 2010 | Black & Decker D2020 Iron
Good morning, My iron black & decker d2020 overheats, cools down and then goes through the process all over again.
Apr 19, 2010 | Black & Decker D2020 Iron
Need the repair manual for a black and decker digital advantage iron. I will turn on but will not heat. rmsc
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the iron isn't heating, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
May 04, 2009 | Black & Decker D2030 Iron
"Standby" on Digital Screen
Leave It Out To Fully Dry Dont Plug In or You Mite Damage The Chip Board
Jul 11, 2008 | Black & Decker D2020 Iron
heatman101
May 11, 2008 | Black & Decker D2020 Iron
How I can fix The Black&Decker digital advantage that does not heat
The iron will probably have to be taken apart.
If you are handy, you can do this when unplugged.
Check for broken connections and anything that is obvious like burned smell etc.
Feb 16, 2008 | Black & Decker AS150 Iron
My iron bahaves very bad
Izula,
We have had two D2020 Black&Decker Irons that did exactly the same thing. I love the iron...but they have both lasted about 2 months before burning!
Dec 02, 2007 | Black & Decker D2020 Iron
Black & Decker D2020 Iron Logo
330 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
