Question about Lexmark T644 Laser Printer
Printer Flushing buffer when using LPR command
Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and not print
  • 2 more comments
  • Raymond Hung Jan 16, 2009
    no , I am getting the flushing buffer overflow problem during LPR print a pure text file under DOS and unix
    I am using the following command and got "Flushing Buffer" at printer
    Windows DOS prompt :
    lpr -S printer_IP -P printer_hostname test.txt
    where test.txt is a pure text file created by text editor at DOS
    At Sun Spac station :
    lpr -p print_q test.txt
    Both got the same flushing buffer result
    printing PS file without any problem
    Thanks
    If you think the lpr send the corrupted data to printer , what lpr switch command should be use for printing a pure text file
    Of cause , open other Windows apps and print it via driver without any problem.
    The problem only apply at LPR printing command
    Genius:
  • 1,665 Answers
Hi!
I would suggest to uninstall driver, run a free scan for driver updates, reinstall and try again.
Link below may helps.
http://www.nodevice.com/driver/T644/get32728.html
Posted on Jan 16, 2009
  • 2,385 Answers
Open the txt file in other application like word or any other word processor the print it.
    Guru:
  • 859 Answers
Do you need to flush your print buffer or are you getting print buffer overflow error?
  • 7 more comments
  • Glenn Rogers
    Glenn Rogers Jan 16, 2009
    Hope that helped, Chris. Why didn't you ask him to clarify?
    BTW, what site did you copy and paste that from I can use it as I'm installing Solaris OS 386, thanks?
  • Glenn Rogers
    RHung33, to clear the buffer and get the dirty data out:
    Use the -c switch and then the user name you are logged on as
    print -c [username]
  • Glenn Rogers
    Chris, Cat got your tongue? Huh?
  • Glenn Rogers
    Chris... what no more BS for this guy? How about the right shell command, or maybe an executable shell command so he may or may not blow out his OS? You're good at that, giving out Shell Commands.
  • Glenn Rogers
    I'd still like to know where you got those commands from as I am loading Solaris OS 386 on a machine. I know he couldn't see my comments. So what's the problem? You didn't respond so I put two and two together So are you for real? Then help me out with the source, mate.
  • Glenn Rogers
    Rhung.
    Its just like DOS. But you may have a bad ram chip on your Lexmark and you can either remove the RAM and then replace it while the power is off of course. Test the RAM module in another printer or reset the entire board. Where you open the printer to access the RAM, there is a button battery Remove the battery for a few minutes unplug the printer, unplug the comm cable from the PC and then reinsert the battery, plug everything back in. You will have to reset the IP address, if its static, set the date and printer name from the printer control panel. But, this will clear out bad data hanging in a good module. If, after this you still have a problem then you have a bad RAM module
    Worldvet
  • Glenn Rogers
    My best guess is that your buffer is lined up with all the print attempts or was corrupted by a bad text file with the wrong line feed command. These things happen. Were you using an esoteric ASCII character ID? That can do it too.
    However, the most probably answer to your problem is the simplest That is the RAM chip is stuffed and needs to be cleared the old fashioned way
    Otherwise, you seem to be doing everything right, not wrong So, I suggest you try my above solution this time. I've done this a lot of time and its a common problem, you really don't want to chase bad data around when the printer is non responsive due to the buffer overflow That's how hackers write viruses to take systems and in your case a printer down.
  • Glenn Rogers
    Are you declaring PRINT and the Line Port as an environmental variable on boot into Windows?
  • Glenn Rogers
    I've sent a note to another expert who can give you a fresh answer you haven't passed over and get you straightened out.
    Solaris isn't rocket science He should help you out.
  • 827 Answers
This means it has corrupt Print Data.
It is the common printer error message for clearing the print-job when it detects corrupt print data.
Try printing something else.. or reviewing what you are trying to print..
Hope this helps
Chris (ziraffa)
  • 2 more comments
  • chris grams
    chris grams Jan 16, 2009
    Make sure your printer cable is okay too..
  • chris grams
    The following single letter options notify the line printer spooler
    that the files are not standard text files. The spooling daemon will use the
    appropriate filters to print the data accordingly.
    -pUse pr to format the files (lpr -p is very much like pr | lpr).
    -lPrint control characters and suppress page breaks.
    -tThe files contain troff (cat
    phototypesetter) binary data.
    -nThe files contain data from ditroff (device
    independent troff).
    -dThe files contain data from tex (DVI format
    from Stanford).
    -gThe files contain standard plot data as produced by the routine plot for the filters used by the printer spooler.
    -vThe files contain a raster image. The printer must support an appropriate
    imaging model such as PostScript® in order to print the image.
    -cThe files contain data produced by cifplot.
    -fInterpret the first character of each line as a standard FORTRAN carriage
    control character.
  • chris grams
    You could use a shared drive and an emulator that
    lets you submit DOS commands from the Unix host. Try a product from
    April Designs in Sweden called Fusion95 to take the place of Advanced
    File and Printer Server, and an emulator called ANITA from the same
    company. They have 30 day trial versions available for download.
    The way I get this to work is by modifying the standard or dumb model to
    put the output in a shared directory on the server. When the file is
    done spooling, issue a DOS COPY command to the emulator to COPY the
    file to the printer port. Since windows is active, the print manager
    picks up the file and does the proper translation to machine code before
    sending it to the printer.
  • chris grams
    Oh hey WorldVet, I'm just trying to help here..
    Don't get abusive, mate..
2 Suggested Answers
  • 13 Answers
SOURCE: posted by rhung33 on Jan
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Posted on Feb 06, 2009
Adobe acrobat distriller 3.0
SYSTEM REQUIREMENTS
Perl 4 or later installed on any of the following systems:
IBM AIX 4.2 or 4.3 with IBM?s Y2K patch installed
HP UNIX 10.x or 11.x with HP?s Y2K patch installed
Sun 5.4/Solaris 2.4 with Sun?s Y2K patch installed
Sun 5.5/Solaris 2.5 with Sun?s Y2K patch installed
Sun 5.6/Solaris 2.6 with Sun?s Y2K patch installed
Sun 5.7/Solaris 2.7
18 MB of hard disk space for Acrobat Distiller
32 MB RAM
INSTALLATION INSTRUCTIONS
The Acrobat Distiller 3.02 for UNIX Y2K Patch consists of two files:
-the distill file, which is the Distiller startup script.
-the distill.y2kfix.pl file, which is a Perl script that is invoked by the Distiller startup script.
To install the Acrobat Distiller 3.0.2 Y2K Update:
1.Make a backup copy of the distill file, which is located in the Distiller 3.02 installation directory. For example: cp distill distill.bak
2.Copy the distill file and the distill.y2kfix.pl file included in the archive to the Distiller 3.02 installation directory.
3.Make sure that the distill.y2kfix.pl file has execute permissions. For example:
chmod a+x distill.y2kfix.pl
4.Modify line 1 of the distill.y2kfix.pl file so that it contains the pathname to the Perl interpreter installed on your system.
5.Modify line 16 of the distill file so that the "install_dir" contains the pathname to the Acrobat Distiller 3.02 installation directory.
Oct 29, 2014 | Adobe PageMaker 7.0 for PC
Troy 8150 Printer
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Oct 31, 2007 | Office Equipment & Supplies
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How to change the density of the printer HP LaserJet 5p
I'm afraid this won't be of much help to the original poster, who asked the question a year ago, but anyway - others may be looking for this too, just like I did...
To change the print density, a simple command must be sent to the printer. This is done in two steps:
  1. Create a file, containing the command
  2. Send it to the printer ("copy" it to the printer, in a DOS shell)
The command is:
<ESC>%-12345X@PJL DEFAULT DENSITY=4
where <ESC> represents the "Escape" character (character code 27). There are several ways to generate the Escape character (which cannot be directly entered in a text editor): E.g. substitute the character with any other, save the command and then replace the first character with 0x1b using a hex editor.
Or:
  • Open a DOS window
  • Enter:
    copy con density.txt <Enter>
  • Hold the <Alt> key
  • type 27 on the numeric keypad
  • Release the <Alt> key - the Esc. char. is shown as ^[
  • Type the rest of the command (e.g. %-12345X@PJL DEFAULT DENSITY=4) - adjust the density value to the one you actually want to set.
  • press <Enter> <ctrl-Z> <Enter> to write the file
When you have successfully created the command file, send it to the printer. In the DOS window, enter:
copy density.txt LPT1
(assuming that your printer is connected to LPT1)
That's it!
To verify that the density has actually been set, print a printer status page.
The printer remembers this setting, so this needs to be done only once.
Mar 31, 2009 | HP LaserJet 5p Printer
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Go Help this Premium Question its basic
The last Lexmark I saw with that "flushing buffer" message only required waiting for the message to clear. Sending commands to it will delay that. The thread was crowded and getting volatile so I don't think another voice would be helpful to the client. Steve also I have two computers I have to have ready by late morning
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
Jan 16, 2009 | Lexmark T644 Laser Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Lexmark T644 Laser Printer Logo
454 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
