Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Power vent tankless heater has a down draft
I have a richmond rmtg-74pvn and I have a problem with the cold down draft is blowing down the vent and freezing the water in the heating tubes.the damper in the top of the unit is functioning properly.
    Habit-Forming:
    New Friend:
  • 197 Answers
I HAD THE SAME PROBLEM ON 2 OF THESE. I CALLED THE COMPANY AND THEY SENT ME A COMPLETE NEW VENT KIT WITH A DAMPER AT THE OUTSIDE WALL. HAVE HAD NO TROUBLE SINCE INSTALLING
Posted on Jan 25, 2010
I got a dryer vent kit (Alum) took the extension pipe off and cut the center hole open a little and slid it over the existing elbow. Now when the heater turns on the little flap opens and when the air flow stops the flap closes stopping the air coming down the pipe.
Posted on Jan 16, 2009
    Problem Solver:
  • 6 Answers
Install a backdraft damper which is like a check valve for vents. Make sure you use only Category III products.
Posted on Jun 10, 2009
I have richmond rmtgh95dv on demand water heater code 13 shows up and i have no hot water how do i fix this ?
Call rheem for the how to on clean and testing the oxygen depletion sensor and check the venting
Jul 02, 2014 | Rheem Paloma Tankless Water Heaters...
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Hi. We have a Paloma Tankless Water Heater model no. PTG-74PVN-1 and we keep getting the error C 7-76 or C 8-76. We cleaned the filter but the problem is not going away. The hot water turns off after a...
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 27, 2011 | Rheem Paloma Tankless Water Heaters...
I have a RMTG-53dvn piped in parrallel with a traditional water heater because I used to have two traditional in parallel. The unit never kicked on with no trouble code, so I piped in series with a...
I could see how it might not work in parallel. Much water would go thru the conventional heater, so there would be low flow thru the tankless.
Now, the tankless is getting hot water from the conventional. Try shutting the conventional heater's power source off so the water gets cold, then see what happens with the tankless.
Gary
Mar 05, 2011 | Rheem RTG-53DVN Direct Vent Natural Gas...
I keep getting a C2 11 error code. Unit lights and immediatly goes out showing that error. At other times it operates fine. The problem seems to be occurring more frequently. It has been in service...
that error code means not enough gas.
however, there might be something going on with your venting. it could be sucking exhaust air back into the unit. this will cause the same error code.
if your problem is intermittent, then I would suspect the venting to be the issue.
Aug 22, 2010 | Rheem Paloma Tankless Water Heaters...
I have a richmond tankless water heater RMTG-74PVN-2 . the unit works most of the time but code c-2 comes up on the display and the unit shuts down. I shut the power off to reset this does not fix the...
I have a Richmond tankless water heater PTG2-42PVN. It will work for a very short time & then I get an error code of either C4 or C7. The remote control alternately flashes IL - 120
May 16, 2010 | Rheem Tankless Hot Water Heater...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
323 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
