Question about JVC KD-S570 CD Player
JVC car radio/cd player wont switch on
My jvc KD-G152 car radio/cd player will not power up. both yellow and red feeds are live although the previous owner has taken both these feed wires from one permanant live wire behind the dash.Not sure if this is the problem but cant see why it should unless red wire need to be dead when using reset black wire is correcltly earthed. system will not power up press the display or eject button and system lights up for about 3 seconds then goes dead again Have carried out reset (on off button together with set button but again nothing)system is almost new but cant return under warranty so any suggetions would be most welcome thanks trevor
  • carl00 Nov 15, 2007
    I have a JVC-KD-S590. It powers off for no apparent reason. I thought perhaps a short in the wiring.But I saw that one solution was to remove the cable from the battery for several minutes. (reset memory??) I tried it, and it worked--but only for a month. I started the car the other day, and the radio had no power again. Took off battery cable again but no good. Any ideas?
  • Anonymous Mar 28, 2014
    UNIT WON'T RESET
  • 48 Answers
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Posted on Jun 29, 2007
SOURCE:
Swapped red and yellow wires on my JVC KD-R200, then swapped them back. Now it only powers on when I push the Eject button. Otherwise, nothing
Swapping the red and yellow wires cannot possibly have any affect on the radio. Both wires need to see 12 volts for proper operation. If they are reversed, it would only simply fail to save the memory settings. You have other issues. You have probably lost power on the red wire.
Dec 25, 2013 | JVC KD-R200 Car CD/ MP3 Player
KD- R538 radio wont turn on
Make sure you are getting power to both the red and yellow wires. Red is switched or ignition and yellow is constant and controls the memory of the radio.
Feb 12, 2012 | JVC Car Audio & Video
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
Need info on wire color coding for jvc car cd player: JVC KD-G140
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
Apr 12, 2010 | JVC KD-G140 Car CD Player
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
I have a jvc KD LH910 an the radio wont work
no security code on this radio. try to unplug the power harness to reset the radio. that should take care of the problem
Feb 06, 2010 | JVC KD-LH910 CD Player
Jvc kd-s590, installing in other car and only the att (red) light comes on no display or sound. tried resetting, fuse is good. that's it.
sounds like only the constant(yellow) wire has power. you need to make sure that the switched wire(red) has power as well. good way to trouble shoot, is to hook the red to the yellow to see if it powers up then, if so you know the radio is ok, you just need to find a better power source for the red wire. hope this helps.
Aug 18, 2009 | JVC KD-S570 CD Player
Jvc kd s 6060
You need to swap the ignition live and permanent live around. If you have a vauxhall the car stereo wiring is the opposite way round to everyone else! Some Rovers have it aswell.
Jan 11, 2009 | JVC KD-S6060 CD Player
JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
Sep 08, 2007 | JVC KD-G110 CD Player
JVC KD-S570 CD Player Logo
971 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
