Question about HP Photosmart D7460 Printer
Printer goes offline for no apparent reason
Also when set to print the control panel shows one print job ready, but nothing happens, Called HP help in India, after hour and a half on phone and talking to three different people, they take control of my mouse and get it to work. However they cannot find any problem with the hardware or software. Printer works for a few days and problem happens again.This has happened at least 7 times.
  • sis4398 Feb 25, 2009
    This happens to me all the time. On my desktop, and on my wireless lap top. Very frusterating. I have tried everything to get it to quit doing this to no avail
  • fliman Mar 13, 2009
    i have a photosmart d7460 hooked by usb to a wireless router and will not print routerncheck ou fine printer always go off line
  • 827 Answers
I don't know if you've tried this already so please forgive me if you have:
I don't know what OS you are using, so I'll presume you're using Vista. Type Services into the search bar and open it. (In XP you click Run, and type services.msc)
On the Services Window, scroll down to Printer Spooler. Right-Click on it and Restart or Refresh it.
Now try and print something.
Let me know how you get on with that!
Chris (ziraffa)
Posted on Jan 16, 2009
HP 5600 printer won't print
Is your HP printer having printing problems due to incorrect printer configuration and driver installation? For the quick tech assistance, you can also go to the Printer USA Support, which is an online directory, offering the certified HP toll-free number that is helpful to directly get in touch with the technicians and get your printer problems repaired in no time. HP Printer Tech Support Phone Number HP Printer Help
Apr 26, 2017 | HP Officejet 5610 All-In-One InkJet...
Print jobs are completed with no problems sometimes, other times the print queue shows the job being printed, but nothing happens. Printer status shows "offline", but if I click on the...
Reason behind "offline" is communication between printer & system got interrupted,check weather printer is restarting it self ? check with another USB cable,check firm ware if low version up load it, check printer USB port on formatter is it dry solder? if no check the voltage in connector 17, between pin 1 & 20 is it 5V? if not check power supply connector J201 pin1, is it 5V? if not replace Power supply PCA.
If 5V showing between pin 1& 20 replace formatter.
Sep 09, 2011 | HP LaserJet 3050 All-In-One Printer
Hp laserjet p2015dn prints one page and then goes offline. i delete the job, then turn printer off. Sometimes, it will show online and sometimes offline. Also, when I shut printer off the light may stop...
Known issue with these printers. The formatters fail at an alarming rate. At one point HP was replacing them under an Extended Service Advisory, but they have discontinued that program. You could try calling and raising a stink and they might do something for you. Otherwise, check on Ebay, likely someone is selling used formatters.
Mar 15, 2011 | HP LaserJet P2015dn Printer
Minolta Magicolor 3100 ... Printer sayes its online and ready to print. When i send a print job it spools it ok but when it goes to print it goes offline. I delete the print job and the printer is back...
Does the printer show any message on it's display ?
Most common problem with these printers is the driver setting (mostly media type/weight) conflicting with the settings made via the front panel menu's.
Jan 04, 2011 | Minolta magicolor 3100 Laser Printer
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
My HP deskjet F4810 printer keeps going offline
hi dear
this link for your driver
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40457-1&lc=en&cc=us&dlc=en&product=1128296&os=228
oke....
post in me back
thks
ropp
Mar 12, 2008 | HP DeskJet F380 All-In-One Printer
HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
Feb 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart D7460 Printer Logo
282 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
