Question about Zenith Televison & Video
Zenith SR1324S 13" manufactured 1995 can not get regular stations, local. only spanish. Tried the menu and to add a station does not work. Would like to be able to add local stations. Help, Please?
I did not solve the problem.. I am going to have to go inside and find a jumper to maybe reset. If you find a solution, please email .
Posted on Feb 05, 2009
MY ZENITH MOD DTT901 DIGITAL CONVERTER ONLY PICKS UP TWO SPANISH STATIONS, 39-1 & 2. NO LOCAL NETS. I AM USING RABBIT EARS. WHAT'S WRONG?
Do you have digital tv that pick up local channels on rabbit ears? If you do, something in the DTT 901 menu is set wrong.
Jun 30, 2011 | Zenith Analog to Digital Audio Converter
Does my 2004 mitsubishi require premium gas or can it use regular
alot of manufactures say to use premium . its not etched in stone though try regular gas if the car runs badly then go back to premium also i would suggest to use stations like exxon/texaco/amocobp these stations add an extra additive to there gasoline that discount stations may not use.
Oct 03, 2009 | 2004 Mitsubishi Endeavor
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
Unable to get stations 17 and 45(UHF)on Zenith model SM2067BT
the problem is station 17 1nd 45 is not yet programmed to your tv...
Sep 11, 2008 | Zenith Televison & Video
Zenith 13in flat screen tv has no picture...
Welcome to FIXya
did you try to unplug it and plug it back in
or maybe goto the menu and try to redo the stations
make sure you have the tv pluged in to a power strip
hope this idea helps out if not please let me know have a good day:)
Jul 16, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
Local tv channels come in snowy
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
Jan 21, 2008 | Zenith C32V37 32" TV
Unwanted Spanish
some times it is due to channel interference or due to weak signal or poor transmission. as your tv is perfectly ok so question of defect in tv. it is outside problem only please check it.
Sep 29, 2007 | Toshiba 32D46 32" TV
VHF stations WILL NOT display. UHF stations WILL display. Have tried both the remote and the controls on the TV. What is the solution?
a no ufh channels would be a setting in the menu, but when your vhf channels go, the problem is typically the tuner itself, or the band switching ic. could be either. you will need a schematic to know what voltage is supposed to be on the pins.
Jan 24, 2007 | Zenith B25A10Z 25" TV
Televison & Video Logo
112 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
