I have two pcs attached to this switch but the kvm switch will not work properly on one of them at boot time, the light comes up when i press and i can see windows starting on the screen but the mouse and keyboard are unresponsive), i am forced to disconnect all usb devices includng the kvm then keep re-inserting the kvm into various usb ports until eventually the pc picks it up, i can then re-attach all other usb devices without a problem. i have tried booting up with just the kvm as the only usb device attached and still the same problem. i have had two OS systems running with this pc XP and Vista and exactly the same problem occurs.. I have a feeling that the problem might be with the motherboard and addressing?? can anyone help???
Thanks tomj23 but i had already tried that, sometimes it would work fine 3 times in a row then stop, sometimes i would only need to take the kwm usb cable out and back in once to work, other times i would have to detach all usb devices and try about 4 or five different connections. i would even get any system sounds or messages saying new device found or disconnected!"£$%^&* Saying this i have found a solution for now, the mouse i was using was a Labtec usb interface which had a serial adapter to connect to the kvm. i switched this for an MS mouse with plain serial connector and i havent had the problem since. 10+ boots and counting. can't test with any other mice as this is all i have. happy for now anyway even though i'm back to my old rollerball mouse, have to give it a good scrub.
I occasionally have a similar problem with a couple of my KVM?s and I think it relates to the circuitry in the KVM that is supposed to fool the PC into thinking a mouse/keyboard is attached. Windows doesn?t see the mouse so it doesn?t load the drivers unless you force it. What works for me is to just start the PC and switch the KVM to that PCs port and leave it there till the computer finishes booting. Then its safe to switch to the other port, probably not the elegant solution you were looking for but it works every time.
