Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool fridge not cooling gone warm air blowing
No cold air is coming out in either freezer or fridge double sided
  • 9 Answers
More than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Posted on Jan 28, 2009
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Fridge side works, but the freezer doesn't
Hi, there is a common fault with these side by side models, the electronics fail in many ways. The first sign of failure is either due to the compressor not working or the 'evaporator' (the cold bit) ices up and air can't pass through it to cool the freezer and fridge.
You can buy a kit to repair the boards for about £30 on ebay
Look for Whirlpool repair
An engineer would charge £200 +
Hope this helps
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cold, refrigerator warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 10, 2009 | Refrigerators
Side by side: freezer temperature fine, fridge too warm
sounds like your auto defrost isn't working. my maytag does same thing. the cooling core in the freezer is probably iced up. when it becomes solid ice no air(or very little) can pass by, leading to too little cold air reaching the fridge. you can try to cycle the temp levers(usually doesn't work) you can manually defrost the freezer. pull the cover off the back(inside freezer) and use a blow dryer. not sure how much parts are for whirlpool. hopefully this is just a one time thing. there are tests you can find to check some of the the heat element for the defroster, just search for the tests.
Jul 30, 2009 | Whirlpool Refrigerators
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
SafetyDan, you probably have a bad starter. i replaced mine its working again. if after replacing the starter you still have the problem then it's a bad compressor but the starter can be found locally or online for about $40-$70 depending on where you live. i found it online here:
Feb 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
749 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
