Question about Compaq TFT5000 15" LCD Monitor
Compaq tft 5000 out of work
Hello, i have a problem with my tft compaq tft 5000: the power supply is good ( i have testing it) but the tft don't light . no led green/orange no light... what's problems on the card? an idea to defectous composants? Thierry
    President:
  • 317 Answers
Your backlight probably went out and needs replaced.
Posted on Jul 31, 2007
SOURCE:
Presario 5415wm won't come on at all. blinking red light on start button
Sounds like the power supply is bad. Does it beep on power up that is the post test to let you know the power supply is good? It is way cheaper to buy a new one then try and repair. hope this helps.
Nov 10, 2009 | Compaq Presario 5000 PC Desktop
Presario 5000 will not start. afterpressing power button, it starts up but immediately shuts down.
If it happens after a few seconds, it may be overheating. If immedietely, the power supply unit is bad.
Jul 23, 2009 | Compaq Presario 5000 PC Desktop
Hp nx 5000 - memory problem
The memory modules are located at the bottom of the laptop under one of the panels.
The memory modules may be OK and may only need reseating. Then boot up the laptop to see if it works, if it doesn't work, the memory may be faulty, take it to a computer shop to get it tested.
Apr 07, 2009 | HP Compaq nx5000 Notebook
Help compaq presario 6000 tower will not power upkbvs
By power up , do you mean no lights. no fans,no sounds? If correct then:
 Check 120 volts going into the power supply.  Check  that the power supply switch is on 1 and not 0 If this fails. Change power supply.
Dec 15, 2008 | Compaq Presario 5000 PC Desktop
Compaq presairo 5000
I would suggest checking the motherboard for any burned or blackened spots on the motherboard or any add-on cards that may be present. You should be able to get something on the display as long as you have good power and a good video card. You still run the risk of having a bad hard drive or cd rom.
Hope this helps. Please make sure that you rate this information.
Thanks
Dec 03, 2008 | Compaq Presario 5000 PC Desktop
Hp zv 5000 won't charge battery or turn on
you need to remove and install the battery. Some times this works first try others may take a few trys. Mine does the same thing. Good luck
Aug 07, 2008 | HP Pavilion ZV5000 ZX5000 Compaq R3000t...
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Hello
I need diagram conections , power suplyy 12 and 5volt of monitor compaq tft 5000s
[email protected]
thank you
Sep 06, 2007 | Compaq TFT5000 15" LCD Monitor
how I solve this issue of a customer of mine.
replaced power supply and one memory stick was faulty
lesson learned: check the obvious first.. .Powersupply.. if problems persists... check your ram... if you have 2 sticks of ram,, try reseating and using one at a time or swap with known good memory.
Sep 13, 2006 | Compaq Presario 5000 PC Desktop
Compaq TFT5000 15" LCD Monitor Logo
262 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
