Question about KitchenAid KESC300 Electric Kitchen Range
PF code on KESC300 Kitchenaid Electric Range
Two of my switches have gone out and now when I turn on another switch (for example the double burner) the entire display lights up and then I just get the clock and the "PF", none of the burners will work at this point. I took out the two switches that went bad but that didn't help. I can't tell whether I need just to replace the two bad switches or if the bad switches somehow hurt the control board?
  • steve_fries Jan 19, 2009
    I'm trying to determine if I need to purchase a new control board for my KESC300 Kitchenaid range. If I don't have any swtiches wired-in should the main display be showing the clock and should the oven controls still work? Currently when I apply power to the unit without any switches wired-in, I get no response from the unit. If I wire-in a switch and turn the switch to the on position, I get full illumination on the display and then a "PF" error code with the clock.
    Sergeant:
  • 221 Answers
Its a power supply problem in your unit .the PF means power failure in the unit. just check out the power cord wire it may be also faulty .or getting cut in between so the required voltage is not been supplied to the unit so its showing this pf on the display.
Posted on Jan 19, 2009
    Genius:
  • 1,665 Answers
Hi Steve_ It is Power Failure code. PF flashes if power loss during a running cycle. Does not flash PF when it is first plugged in.
Press START to continue from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
  • 59 Answers
Check out this site http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KESC300 you can purchase your part and it will give you exploded break downs on how to dismantle it.
  • 470 Answers
These switches are too sensitive be careful my dear, you need a technician on it, cause replacement of the switch is taking the wiring and reprogram it again, the delicate part here is the wiring process, don't repair it by yourself, because it can cause short circuit,, call a technician for the safety of your kitchen range
Posted on Jan 17, 2009
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 22, 2009
    this was considered a FIRE HAZARD!!, A couple of
    days later the maytag guy had broken the backplate of the metal support
    brakets behind the control board (which was the root cause of the
    problem, until then...) Maytag guy leaves the premises, a couple of
    screws left behind, .. now the cleaning cycle does NOT work.. As you
    heard before .. they make emphasis to the point of NOT BUYING EXTENDED
    WARRANTIES... SO I clean the oven myself
  • 818 Answers
Sounds like the element switch for that burner has shorted contacts and
likely needs to be replaced.
In order to get the proper replacement part, you'll need to get the *whole*
model number off the appliance or the part number off the old switch (if
there is one). You can read tips for finding the model number on your major
home appliances in the 'Repair Parts' section of my site linked below.
http://ng.Appliance411.com/?re f411=KitchenAid+cooktop
    Sergeant:
  • 270 Answers
Depending on how long it was in this Condition Before you made the Repair, If the Switches are new as you Stated It will be a Main Control Board Problem.you should replace it.
  • 180 Answers
The control switch is bad, they are very sensitive to voltage spikes, mine was caused by lady bugs in my breaker box.
  • 106 Answers
It won't work properly until you replace those two switches..
good-luck ray
    President:
  • 1,990 Answers
Welcome to Fixya! Depending on how long it was in this Condition Before you made the Repair, If the Switches are new as you Stated It will be a Main Control Board Problem.
  • Travis Humphries
    Travis Humphries Jan 19, 2009
    Yes Yes and Yes. Even with the New Switches, You are still going to get Error Codes From the Board. The Board Definately is Bad and Should be Replaced.
Is this considered a single throw switch or a tripple throw switch and what's the difference
We cannot see the product you are asking about
Example single throw switch is household light switch ..., flip the switch either direction and load turns on-off.
Example double pole switch is 240 volt double breaker... flip the breaker and two wires turn on-off.
Example triple pole switch is any 3 phase contactor or 3 phase timer ... flip the switch and three wires turn on-off
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/3-Pole-contactors.html
Gene
Water Heater Timers Save Money
Apr 27, 2015 | Electrical Supplies
Kitchenaid electric range model kesc300, why does oven go on by itself and i cant shut it off unless i closs circuit breaker
Ghosts....
Okay, at this point some trouble shooting is needed. Unless you have a multi-meter and know how to use it you need a professional. Surges in thesource may cause this as well as poor grounds in the builings electrical sysytem.
Oct 09, 2014 | KitchenAid KESC307 Electric Kitchen Range
Ignitor not working
This sounds like the switch for that specific burner is bad. You will need to order the switch for that particular burner. Sometimes it is the entire harness that will need to be replaced because all the switches come as a set. The front or top switch panel will have to be removed to replace the switches. Turn off the power before attempting any service.
May 01, 2013 | KitchenAid Kitchen Ranges
How to change language English
You can find the manual for the Jura IMPRESSA S9 One Touch at the link below. I have typed the Instructions from the Owner Manual Below. See: http://content.costco.com/images/Content/Misc/PDF/OwnerManual-671992.pdf
Program Language:
Example: To change the language from ENGLISH to DEUTSCH (example), proceed as follows.
Precondition: COFFEE READY is displayed
  1. Keep the Rotary Switch pressed until MAINTENANCE appears.
  2. Turn the Rotary Switch until LANGUAGE ENGLISH is displayed.
  3. Press the Rotary Switch to enter the programme item. LANGUAGE ENGLISH
  4. Turn the Rotary Switch until SPRACHE DEUTSCH (example) is displayed.
  5. Press the Rotary Switch to confirm the setting. GESPEICHERT (example) appears briefly on the display. SPRACHE DEUTSCH (example)
  6. Turn the Rotary Switch until EXIT is displayed.
  7. Press the Rotary Switch to exit programming mode. BITTE WAHLEN (example).
Best of Luck!
Jan 14, 2013 | Jura Impressa S9 One Touch
Burner isn't working
Check the burner for continuity with a multi-meter. Post back the results.
Dec 09, 2012 | KitchenAid KESC300 Electric Kitchen Range
After cleaning, the oven will not work, it keeps flashing F5, whats the problem?
Hello & Welcome to FixYa
Error code F5 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | KitchenAid KESC300 Electric Kitchen Range
One of the top burners will not turn on or will come on for a short time and kick back off...
Remove the burner element by pulling it up slightly then towards you.
There are 2 terminals on the element that plug in to the receptacle in the range opening.
Gently spread the 2 terminals apart. Not too much.
Then re-insert the element into the outlet and turn on the range.
Nov 27, 2010 | KitchenAid KESC300 Electric Kitchen Range
I have replacedsurface unti terminal block with kit supplied by whirlpool part dealer. Though all other burners work on stovetop, the large burner still won't heat up. I alsp bought brand new element from...
Good morning,if you've replaced the burner and block and it still isn't heating,you definitely have a bad burner switch. On an electric stove you have two lines of 115 volts going through the switch to the burner. If one of the lines through the switch has burnt out,you may still get the burner on light. Hope that helps.
Jun 05, 2017 | Whirlpool RF302 Electric Kitchen Range
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KESC300 Electric Kitchen Range Logo
1,961 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
