Question about Garden
Carb adjustment i need to know how to adjust the 2 adjustment screws on the carb and were they should be at for turns out. every time i thank i have them set. engine dies when i star to get into snow can get it to run great just setting there idleing. can anyone help toro cr20e snow blower modle 38116
  • 2 more comments
  • bill9932 Jan 22, 2009
    problem fixxed have no way to remove question
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello bill did you get my request about the problem you posted,could you let me know,if not so be it.thank you.
  • JERRY ABELL
    hello! you need carb. adjustment on what kind of engine??
  • JERRY ABELL
    hello! Ok What Kind Of Mower Do You Have. What Kind Brand Of Engine,Horse Power; Let Me Know So I Can Hekp YOU; MrFixIt
Screw both screws right in (don't force them) Then turn each screw out 1 & half turns each OUT. This will get engine running. To fine tune- turn low speed screw out, bit by bit, while idling, till engine revs change, then turn screw in till revs change, the correct setting will be somewhere between the 2 adjustments you just made. Do the same thing to the high speed screw, but with full revs. Good Luck. Stevo..
Posted on Feb 18, 2009
I have a 92 golf 1.4 carb engine and its burning to much fuel for the emissions, Any 1 got any ideas howto solve this. Thanks
1 make sure the choke is not sticking
2 see if you can get to mixture adjusting screws toward the base of carb to adjust in.If there are two screws you have to adjust the both of them the same.Do thes a 1/4 turn at a time.
Feb 04, 2013 | Volkswagen Golf Cars & Trucks
2005 Honda CRF 80 F carb adjustment
Hi, Kyle it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda CRF80 Carb Adjust Mixture Screw Mod
2007 Honda CRF80F Motorcycle Idle Speed Adjustment Attempt CRF80F CRF100F service manual repair 2004 2013 CRF80 CRF100 Download... $15
https://www.partsfish.com/page/oem-parts-for-honda
HONDA CRF80F Owner Manual
Jun 23, 2012 | 2005 Honda CRF 80 F
For a Homelite String Trimmer ST155CKD which has had it's mixture needle removed, how many turns back from fully in should needle be reset?
Hi and welcome to FixYa, I am Kelly
Turn it until just closed (fully in) then back it off 1.5 turns. Yuo will have to dial it in again...
For one screw type carbs... turn the H screw until it runs MAX speed and will idle.
For 2 screw carbs H & L screws adjust the L screw first until it idles and does NOT stall or hesitate when you MAX the throttle. Then adjust the H screw until you get MAX speed. Re-check for hesitation or stalls. Re-adjust L screw if necessar and dito for the H screw after re-adjusting L screw.
NOTE make minor adjustments each time.. not much more than the width of a screwdriver blade. Your final adjustments should not be more than 1/4 turn from where your started.
Set idle speed screw stop last on the top of the carb to get a decent idle.
This should get you going.
Thanks for choosing FixYa,
Kelly
Jul 01, 2011 | Homelite Garden
Need to know about carb adjustment for tomos st sept 2010 question 1 the screw adjust questtion 2 finger turn adjustment what do either do and if totally screwed in how many turns out do i do...
LIGHTLY seat the air screw and the throttle screw. Now open both of them up one and one-half turns. Adjust idle speed with the throttle screw. Normally, the throttle screw sticks out about 1/2" to 3/4" from the throat of the carb. The air screw is short and usually recessed. If the screws have been tightened down anything more than lightly, the screw seat may have indented the screw face. If the face is ringed, the engine usually will not run well. The screws would need to be replaced. Please rate my answer. Thanks.
Apr 08, 2011 | 2008 Tomos Se 125 F
How do you adjust the high speed mixture screw? I have a Ryobi RLH1100a MK III 31cc line trimmer, and after changing the fuel lines, it will start but not idle more than about 3 - 5 seconds before it...
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Feb 28, 2011 | Ryobi Garden
I have a Briggs & Stratton 5HP Engine (Horizontal shaft) And it has the diaphragm carb on it. The last person to own it messed with the carb adjustments and it'll have trouble starting and idling...
2 turns out should get ya started adjust from there. If adjusting doesn't help you may need a new diaphragm. While you have diaphragm out blow through the 2 holes you'll see under diaphragm with air to hopefully avoid pulling carb off to clear screens on pick up tubes. Also check carb mounting screws through carb into tank. They frequently come loose on chippers and log splitters because of hard mount.
Oct 07, 2010 | Mtd Heavy Machinery
Need to adjust my honda shadow 500 vt carburator's fuel/air mixture
start by synchronizing your throttle plates. Honda calls the next step the "idle drop procedure". u need to know if you have fuel adj. screws or air adj. screws. fuel screws will be on engine side of carb slide, air screws will be on airbox side of carb slide. start leaning out mixture, (turn in fuel screw, turn out air screw. idle will increase so keep adjusting idle back to spec.after each turn if needed. Adjust about 1/4 to 1/2 turn at a time on each carb until there is no change in idle, then richen up mixture by one half turn. If u sync throttle plates first then follow this procedure, there should be no hesitation when you "blip" the throttle, and after revving it should return to idle smooth,
Apr 08, 2010 | 1986 Honda VT 500 C Shadow
CLEAND CARB NEED TO KNOW HOW TO ADJUST CARB
Most carbs have the adjustment removed (EPA) but if yours still has the adjusting screws here are the seat of the pants methods:
One Screw Carb: Turn it all the way in and then back out 3-1/2 turns, start the engine and make slight turns in or out until the motor runs smooth from idle to wide open, do not get it too lean, turn in until max RPM is reached then turn out 1/8 turn and go from there.
Two Screw Carb: You adjust the one to remedy either the low or high, high is adjusted until the motor runs smoothly under load at high RPM and the low is adjusted until idle and off idle is smooth.
Feb 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Hyosun Scooter Carb Adjustments
Very good thought process on the adjustments. The throttle screw sets the idle speed and the air screw sets the fuel mix at idle speed. The stock setting is 1.5 turns outward. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward.
From this point you adjust the idle speed then adjust the air screw for fastest idle speed at that throttle screw setting. If the idle speed becomes faster than desired after adjustment, just reset the throttle screw and then reset the air screw.
A “very helpful” rating for this answer? Thanks!
Jun 27, 2009 | 2002 Hyosung Comet 125
Homelite Blower HB180V carb adjustments.
Hi
high speed H=2 turns ,lowspeed L=2 1/2 turns
they are inscripted near the adjusting screws.
regards savumihai71
Dec 05, 2008 | Homelite Garden
Garden Logo
777 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
