Question about Uniden UDC7M Digital Camera
Camera dropped in sand
My camera was recently dropped in sand by a 'helpful' passerby, now it wont turn on properly and it says on the screen "SYSTEM ERROR". how can i fix this?
    Genius:
  • 2,985 Answers
Err well you cannot I would guess. Try running a vacuum cleaner over it to suck out any grit. Do not put airline to it - it will blow any grit in further. But that is about all you can do any thought on sending it away will be as expensive as buying the next camera.
Posted on Jul 13, 2007
Camera wont focus
If it recently sustained a drop or other impact, the lens mech is damaged. With the lens out, visually inspect it to see if it may be slightly crooked or askew. If so, gently try to "pop"it back into alignment. If not, sand or other debris may be caught in the mechanism. While the camera is turning on and the lens is extending, gingerly (but firmly) tap the cameras bottom against a counter or other hard surface. This will often let the debris work its way out.
Let me know if this works or not.
Jul 03, 2011 | Olympus Stylus 7030 Digital Camera
I have tried all that is on this site i have the powershoot and fiance dropped it in sand got the error lens message and now it wont turn on at all.
The Lens has been damaged and cannot move in and out properly or focus properly. You will have to either buy a new camera or get yours fixed. This kind of damage is not covered under your one-year warranty so you will have to pay for repairs. To get it serviced, contact Canon customer service as listed in your manual.
May 04, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Focusing Problem
hi, if you can open your camera and remove the lens unit assy(just be carefull to the flat cable its easy to be broken) you can clean by yourself just to remove the sand goes inside of the lens unit and also to the gear.make it sure you need to use magnifying glass to see the small pc of sand .some time the sand goes to the gear that cause of malfunction or not rotate properly and also the focus gear have also sand that why the focus is bad.if you can't do this just bring to service center and request for cleaning.
thank you
Jun 19, 2010 | Casio Exilim Card EX-S100 Digital Camera
I dropped my mx1063 in the sand at the beach. I
This is not a user solvable problem. One thing that should not be done is to turn on the camera when it has been dropped in dirt, sand or water. This will, in your case, grind the dirt around and parts try to move and contaminate additional parts of the camera. It's only worse if water is involved as this will likely cause shorts in electrical areas.
Take the camera to a repair shop and get their opinion on whether it is fixable and if so what they estimate the cost to be. Sometimes it's cheaper to buy a new or used camera.
Jul 22, 2009 | Kodak EasyShare V603 Digital Camera
When turn camera on lens opens and close
there is a friction in the movement of the lense assembly. It is not reaching to its proper position. This happens if you drop the camera, or the camera is exposed to sand. a repair technician can fix it.
Mar 21, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Digital camera got dropped into the sand, and some sand worked its way into the lens and focusing system, and now the camera cannot zoom or focus, but still turns on and takes pictures i have a lumix dmc...
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Nov 04, 2008 | Cameras
My cammra wont take pics and the lenze wont go down, i droped into the sand, got all the sand off of it though.
Dropped digital cameras are usually dead digital cameras. No matter how careful you are sand and dust can get inside and raise havoc with the internals.
Aug 12, 2008 | Nikon Cameras
When I turn on my Camera, the screen turns blue and say Zoom Error in red writting, and it wont turn on, and the shutter will not shut!
This happens du to friction in the movement of the lense assembly. Did you happen to drop it in sand or on hard surface. If the camera if exposed to sand, just the cleaning of the lense assembly,( gears and the barrels) will solve the problem. But, if any damage is there then the complete lense unit needs replacement.
Jul 17, 2008 | Olympus Cameras
Dropped fe- 230 camera in sand..spazzing out..help ASAP please
Borrow a friends camera or buy another.
The motorized lens assembly is contaminated, and
your only recourse is to replace the entire assembly.
It has very close tolerances and even replacing it is no guarantee that all the sand particles could be cleaned out of the camera body.
Sorry. No easy fix this time.
Regards Paul
May 30, 2008 | Olympus FE-230 Digital Camera
Uniden UDC7M Digital Camera Logo
83 people viewed this question
Top Uniden Cameras Experts
Marvin
Marvin
Tom Chichester
Tony Parsons
Tony Parsons
Are you an Uniden Camera Expert? Answer questions, earn points and help others
