Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Send data over T5720 ?
I use a T5720. How can I use it to send data over it ? thanks Arshad
  • Arshad Kadiri Jun 19, 2007
    thanks Neto.
    Can you recomend a solution for GPS tracking over VHF radio for about 10 vehicles covering 100 Kms ? The vehicles already have Motorola GM338 (25W VHF mobile radio).
    Thanks
Create your own protocol .. try to see how wide is the channel and then try some solution like sending pulses in morse code whith location .. or translate nmea protocol into pulses .. the thing is u will need some kind of device made speciaally for your need's .. I don't known if it's possible to send data whith an old modem 33 kbps or less .. it depend's on the bandwith of the channel but that's an other option ...but it'll hace to be half duplex and the talk/no talk action will be hard yto implement .... a verry simple option is ..... a code at the beggining .. s eries of pulses separated in thime so that the machiine knowns the truck is triing to communicate .. and then send each numbres of the lat and long. in pulses ...a specific time .. it's slow and noise sensitive but it's something ...
Posted on Jun 21, 2007
  • 123 Answers
Those radios were not designed to transmit data, and has no any port for it.
Posted on Jun 18, 2007
SOURCE:
Phone want send email
1 - Press Volume + , Home, Power
2 - use volume to select wipe data/factory reset
3 - Yes (delete) all user
4 - It will reboot
5 - Done
Good Luck!
for join me on facebook add me from here :
https://www.facebook.com/awais.arshad.127
Oct 20, 2013 | Samsung Galaxy S GTI9000 Smartphone
Hi everyone I am very new in the telecom field and so interested on BTS. Please I would like to get all the materials and data manual with BTS installing and commissioning for GSM and WCDMA........ if...
Hi everyone I am very new in the telecom field and so interested on BTS. Please I would like to get all the materials and data manual with BTS installing and commissioning for GSM and WCDMA........ if you have document please send through the below email address; Thanks
May 06, 2011 | Computers & Internet
We have two talkabout t5720, both set on same channel. One seems to send, while the other does not. we haven't used them before-is there a simple solution? Thanks
Yes. The solution should be simple. The radios are possibly not set to the same interference eliminator code and/or Qt filter setting. Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
You will find the programming instructions begin on page 21.
The frequency, code and Qt filter must be set identically on both radios. For simple basic operation set the code and Qt filter to zero (off).
Best regards.
Mar 14, 2011 | Motorola Talkabout T5720 (7 Channels)...
Got error of "PC cannot send datga to printer. Please check power
my printer, I got error of "PC cannot send data to printer. Please check power and printer cable connections and retry printing". Please help me.
Apr 02, 2009 | Sharp AL-1642CS Copier
I have a TLKR-T3 and a T5720 radios. can they communicate? Thanks
No, they have no frequencies in common. The TLKR-T3 uses the PMR446 frequencies common in Europe. The T5720 uses FRS freqeuncies common in the USA.
Dec 19, 2008 | Motorola Talkabout T5720 (7 Channels)...
Normal RS -232 cable
5 4 3 2 1
9 8 7 6
1 - Not Used
2 - Transmit Data (TD)
3 - Receive Data (RD)
4 - Request to Send (RTS)
5 - Clear to Send (CTS)
6 - Grounded
7 - Signal Ground (Gnd)
8 - Data Carrier Detect (DCD)
9 - Data Terminal Ready (DTR)
Sep 30, 2008 | Computers & Internet
RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Sep 22, 2008 | Motorola Talkabout T5720 (7 Channels)...
Comms problem between motorola t5522 and t5720
Are you sure both radios has the same Squelch Code and QT?
Jul 07, 2007 | Motorola Talkabout T5720 (7 Channels)...
Pin out for t5720
the Plug is a 2.5 mmm the tip is mic, middle speaker, the end is gnd.
Jun 19, 2007 | Motorola Talkabout T5720 (7 Channels)...
How to open the T5720?
for 5720 - open two screws below battery compartment. and two screws are under the front false faceplate. Pull out the face plate (from the top) and unscrew the two screws above the display. walla you have it dismanteled ! Arshad
Aug 19, 2006 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
77 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
