Question about Reddy Heater-30-55,000 BTU Variable
No heat, just smoke, flame inside,
I have a M50S Ready Heater, it is on kerosene, just ignites inside but flame does'nt go to the end of the tube and make the cap glow. Just smokes and acts like its working, but just blows cold air and smoke.
    Sergeant:
  • 359 Answers
MORE THAN LIKELY NEEDS SERVICED START BY REPLACING FUEL NOZZLE WITH THE SAME NUMBERS THAT ARE ON THE OLD ONE SHOULD HAVE 2 NUMBERS ON IT DEGREE AND GPH RATING MATCH BOTH GOOD START AND LEAST EXPENSIVE AND MOST COMMON PROBLEM FOR WHAT YOU DESCRIBE
Posted on Jan 17, 2009
Have a R35a that was stored with kerosene for 2 yrs. Electric motor runs and it tries to ignite. belches some smoke and heat intermittently then just blow air
your pic is a propane heater but model # a kero heater any way check lines to the air and fuel for cracking filters have to be clean in the heater and foam on the out not sure what the pressure is for that model but findable table on the ready heater look up get the old fuel out and new in good luck ready was the best
Nov 30, 2013 | Reddy Heater-30-55,000 BTU Variable
My ready heater 100,000 will run for app. 5hrs then flame out and blow smoke or unburned fuel the same several times pressure is right
If the heater continuously has a 5 hour run-time check to see if the fuel pickup tube goes to the bottom of the tank. If broken, cracked, or shortened the fuel will stop being picked up when air is sucked rather than fuel.
Feb 08, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Jan 25, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Won't ignite and fill the entire tube with flame, cold air, smoke
The deisel fuel hogged it up. Clean everything out and replace the wick. Deisel fuel is filthy to burn and it needs a lot of airflow.
Jan 16, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Was running fine, then shut off and smoked like out of fuel.
THERE ARE THREE OR FOUR REASONS FOR THIS. DIRTY FUEL FILTER, FUEL PRESSURE INCORRECT, DIRTY AIR AND LINT FILTER, THE ELECTRIC EYE THAT SEES THE FLAME IS BAD, OR THE CONTROL BOARD IS BAD. THESE ARE MANUFACTURED BY MESA OUT OF BOWLING GREEN, KY AND THEY HAVE A WEBSITE. I GOT MY NEW PARTS AT MY LOCAL RURAL KING STORE.
Jan 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
30,000 btu kerosene ready heater
check pressure of the air compressor should be in the 3.0 to 3.5 range. not enough won't suck fuel, too much will blow out the flame. igniter either lights or it doesn't no in between. does the main flame come on?
Jan 05, 2008 | Heating & Cooling
Reddy Heater-30-55,000 BTU Variable Logo
95 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
