Question about Toshiba 27DF46 27" TV
No picture, only sound
When I turn on the TV the sound is on but the screen is black except for a narrow horizontal line across the middle and you can see a tiny bit of the picture . All inputs have been checked and they are all good. My TV is only 14 months old. This problem started about 2 months ago but only did it occasionally. If I turned the TV off for a couple of minutes and then back on, it would work. Now that doesn't work at all. I had the cable company here to check it out and he said he thinks it's the picture tube. What do you think? I also called a TV repair service and he said this happens with a lot of Toshiba TV's
  • ShadowXXXIX Mar 04, 2008
    I have a Toshiba CF1926A and I've gotten the same problem. A black screen with only a horzontal line across the middle though the sound is perfect. I tried to turn the set off and on, but to no avail. I thought that it might have been a storm or a power surge, but when the cable technician came out when the channels ceased to work, he said that it was only a bad splitter elsewhere. Then my TV worked fine until two days later. It happened before, but the line was thicker. It's getting thinner and thinner. It was built in October, 1991, so based on the repair cost that you mentioned, I'll be buying a new set.
    Scholar:
  • 47 Answers
The set has a shorted vertical output IC, probably a TA8427k. The capacitors around the heat sink of this IC dry out and cause the IC to run hot. The correct repair is to replace the vertical output and the electrolytic capacitors near it. Also use 105 centig instead of the original 85 centigrade. The is some time a pico fuse or current limittng resistor which must also be replaced. This a common problem with Toshiba and is not a bad picture tube. The usual cost of this repair is around $120-150 depending on the integrity of the technician. Scrivitron
Posted on Jun 29, 2007
    Problem Solver:
  • 7 Answers
I sorry but i tend to agree with the cable guy. It s not uncommon. If you see a dot on the screen or the Pic. is reduced to the center of the screen it is a hint that there is something wrong with the pic tube. Not necessary the pic tube but something along the lines. I would call Toshiba and find out about the warranties on there product. Good luck.
Posted on Jun 18, 2007
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Picture is black except for colorful horizontal line across tv
It sounds like you need a DEFRAG Done. Have you put any new speakers or magnets near the TV? Has anyone had a magnet toy or things around the TV lately?
Feb 23, 2009 | JVC AV-30W475 30" TV
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Mitsubishi CS-3515R tv problem
is locked and forgot my 4 digital code number
Jan 21, 2008 | Mitsubishi CS-35503 TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Toshiba 27DF46 27" TV Logo
201 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
