Question about Samson R21S Microphone
Trying to use a microphone but not sure how to hook it up
I just bought a microphone and the only hole that I can put it in is the phone one but someone told me that is only for headphones. Do you know if I can use that imput hole with a converter or something?
  • 905 Answers
"phone" on a reciever or radio means it is for headphones only, there is no converter that will or can change the internal output circuit of a radio , reciever or" phone"( headphone ) output on a output made only for headphones or ( an output circuit into an input circuit )
recievers or radios the have a microphone input will be labled "mic.L" or "mic.R" or just "mic"
Posted on Jan 16, 2009
    Genius:
  • 1,199 Answers
No because the mic is a signel in device and the headphone jack is a signal out jack! meaning if you plug the mic into it the mic will act as a speaker and music will come out of it and ruin it!
I would buy an adapter at radio shack and plug it into the phono input on the back of unit! and if you dont have a phono input you will need to buy a small pre-amp and plug it into the aux or tape input!
That will work!
Please rate my answer!
Thank You!
Why can i hear caller on my verizon cell phone but thet cant hear me?
The most common cause for this is the microphone on the phone to be non-functioning or obstructed. Depending on what model of phone you have will determine the location of the microphone. It's typically a small hole about .5mm wide near the bottom of the phone. Make sure nothing is obstructing the hole, like a phone case covering it or debris clogging it. If this doesn't work, it's probably time to replace/repair the phone depending on the age/model of the phone.
Jul 29, 2014 | Verizon Communications Cell Phones
Microphone not working
Caution! I hope you backup your phone, because this WILL erase everything in the phone. Contacts, apps, messages, EVERYTHING. A hard reset may be the only way to fix this issue. It is a ZTE Chinese phone, from Hong Kong.
Make sure moisture has not leaked into the microphone hole. Make sure the phone was not dropped or damaged.
CLICK HERE
Oct 18, 2013 | Virgin Mobile PCD Chaser Prepaid Cell...
I am trying to hook the mic up to my computer in the location for microphones and it is not working. i also tried via my tv and stereo system. it will work to receive sounds if plugged into the phones
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 23, 2011 | Samson R31S Microphone
Hooked up my Bose companion 3 series II speakers but cant get sound. Which input hole do I put the audio cable? I put in the speaker jack that the original ran off of but its isnt working I have a dell xps...
Hi there , and happy new year ... The Cables are usualy Colour Coded , so try plug the Green Color coded Wire into the Green Jack Socket ...make sure it isnt connected to the Microphone socket..
Hope this Helps Bud
Have a Great Year: )
Dec 30, 2009 | Bose Companion 3 Series II Multimedia...
Callers can not hear me when I answer
First, I would remove the battery and put it back in, this will reboot the software on the phone.
If that doesn't help try the following steps.
the microphone is on the bottom of the phone a small hole.
make sure there is nothing blocking the hole. lint or a case or whatever.
that hole has a passage that goes to the actual microphone so it must be clear.
also if your phone is not unlocked, you can reload the software in desktop manager to make sure it's not a software problem
the last is to replace a faulty microphone. it requires a part and take apart the phone.
Jun 07, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The person I am calling /trying to talk to can not hear me
You need to configure your microphone settings.
When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
I don't know the audio/microphone setting for Phone Serve.
Apr 14, 2009 | Dell Inspiron 1525 Notebook
I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Dec 31, 2008 | Linksys Cable Modem
NO ONRE CAN HEAR ME !!!!!!!!!!!!!!!!!!!!
Is it possible that something is blocking the hole to the phone's microphone? Check that the hole is clean (usually from dust). Good luck!
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Handset not working
I had this exact problem. My solution was to clean the top of the condensor microphone. Something was spilled onto the phone and ran down into the hole that leads to the microphone. It not only affected the microphone, but made some of the buttons stick as well. The phone is not difficult to disassemble, just try not to touch the electronic components. If you are experienced in electronics, you may know that using a wrist strap( available at electronics supply stores or online) and grounding yourself will help protect the electronics. While you are at it, get some pure isoproply alcohol, and some cotton swabs, making sure that the swab is saturated with the alcohol. Just clean around the interior area of the phone where the condensor microphone is. You will want to even remove the black screen over the microphone to be sure everything is clean!!! Make sure the little hole that leads from the front of the phone to the microphone is clear and clean. I believe you will solve your problem.
Sep 23, 2007 | Uniden DCT648-3 Cordless Phone
Open Questions:
Its way too quite. Ok I've had this problem since day 1 and have pretty much given up on any hope for this mic, I bought this mic so i could have better quality audio when I record my gaming videos and yet every time I try to record or use it on my chat programs the **** thing is so quite that to get any sound to be picked up it has to pretty much be in my mouth. Now to give an idea of the situation I'm using a PC first off and its a desktop not a laptop like a lot of the other problems I've seen here about this mic and second I don't have a bunch of audio equipment or any other kind of recording studio gear just me, my computer and the mic. I've tried plugging it into my guitar amp but it pretty much did nothing at all so ya if there is a free software I can download to increase the volume of the mic that'd be great but I will also be using this while in chat programs such as Skype, Ventrilo or Mumble so of course it has to produce the same level of volume in all of these things. At the moment I am forced to use the mic from my Turtle Beach x11 Earforce headset which is not the best quality but it's not bad and picks up everything I say from about 10ft away. So if anyone can give me an answer that helps with this that isn't blatantly obvious like going into the recording devices section of my computer and changing things there because I've done that already (enhancements available DC offset cancellation/ Advanced set to 3 channel, 16 bit, 192000 Hz).
Mar 01, 2017 | Samson R21S Microphone
Samson R21S Microphone Logo
482 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
