Question about Sony Cyber-shot DSC-W110 Digital Camera
Lens problem Camera fell down and the lens is stucked. tried to switch it off and on again , but nothing is working , please help urgently ////
  • Anonymous Apr 16, 2009
    my camera didn't fall but all of the sudden it wont open and it sounds like the lens it stuck ... it tells me to turn it off and than on again but it doesn't work and the camera is only 18 days old
    Genius:
  • 2,985 Answers
The lens mechanism would seem to be damaged in some way.
There is normally no repair solution with this sort of thing because of the fine mechanism involved.
If you have someone you know who can work with fine instruments to take it to pieces.let them try.
I guess as no repair option is available you cant make it worse by trying to find out
Otherwise - new camera
Posted on Jan 16, 2009
Sony cybershot camera fell and lens is stuck
The lens may be out of position, or there could be dirt/dust in the lens mechanism. You could try some of the following suggestions:
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
Sep 07, 2014 | Cameras
My sony cybershot mpegmovieVX dsc-92 fell down and it's shutter is stuck inside. I cannot go buy a new camera OR go get it fixed. How do you fix it I need help :( urgently
Sorry but usually when the camera lens is forced shut, the gear mechanism will get out of sync. Usually even if it will open, you will receive a Lens Error
Jun 25, 2011 | Sony Cyber-Shot DSC-P92 Digital Camera
The lens problem I have involves a scary clicking sound that makes me think that the barrels refuse to retract. Restarting and such works, but after zooming in (for macro shots, and other), the lens...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Dec 14, 2010 | Canon PowerShot A480 Digital Camera
It fell on the tile face down on the lens, and the lens is stuck. When i turn it on, it says turn off and on again. Please help!
Hello
Regards
Andrea
Nov 07, 2010 | Sony Cybershot DSC-S950 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Goes off after lens come out.
Get it repaired under warranty. Sounds like a logic circuit problem.
Dec 10, 2008 | Pentax Optio S50 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Sony dsc-w55 fell and the lens is stuck
Use bit more force to push or pull the lens as lens has been damaged. If applying bit more force lens goes to working, u saved $$$ otherwise, new lens option is always available at Sony repair shops.
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Optio S5i Stuck Lens
Hi: First of all, with that behavior, your lens are stuck. Probably the problem was on the assembly. Try to disassemble and assemble them again. Regards
May 16, 2006 | Pentax Optio S5i Digital Camera
Sony Cyber-shot DSC-W110 Digital Camera Logo
175 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
