Question about Samsung SyncMaster 510N (Silver) 15 inch LCD Monitor
Monitor goes black
After switching on the comp, the monitor shows a box with these things written on it------ NOT OPTIMUM MODE, RECOMMENDED MODE 1024*768 60 Hz ? I have checked my settings and they are set to the same resolution and refresh rate. What to do?
    New Friend:
I have sam 510N its shows AUTO ADJUSTMENT LOCKED and NOT OPTIMUM MODE what should i do?
Posted on Jun 10, 2011
  • 84 Answers
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
Posted on Jun 19, 2007
SOURCE:
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
Feb 09, 2012 | Computers & Internet
Not optimum mode Recommended mode:1280X1024 60 Hz
u can change logic board r update bios using with ddc manager
Jan 18, 2011 | Samsung SyncMaster 713BM 17" LCD Monitor
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
How do I change the setting on my Syncmaster monitor if I can't see anything but the message box..."Not Optimum Mode recommended mode 1280x1024 60 hz?
You could try pressing the auto adjust button (simply says 'Auto'), and see if that changes anything...don't know if this will work, but it is a start.
Sep 29, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
"Not optimum mode" on SyncMaster913v monitor
In Windows (since it's a laptop I'll assume you're running Windows XP)
right-click on the desktop, select properties, and go to the settings tab.
Click on the display with the 2 in it, then set the resolution to 1280*1024.
If that doesn't work, you should check wether the desktop is extended to that display, or cloned on it. It should be set to the first.
by the way, in safe mode the resolution is always set to 800*600.
This should fix the problem!
If it doesn't, just post what happened here.
Sep 09, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Samsung SyncMaster 510N (Silver) 15 inch LCD Monitor Logo
428 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
