Question about Car Audio & Video
I think that there may be a short in my car audio bc a fuse blows every time
  • Ronnie Wilson May 11, 2010
    i think that there may be a short in my car
    audio bc a fuse blows every time ??????????
    NEED DETAIL
  • 3 Answers
The fuse trips for a reason, probably blown output stage ..needs a service or replacement
Posted on Jan 16, 2009
Any fuse I fix it blow it
Your question is to vague however I'll pass some ideas.
the fuse blows because you have a short. Now not sure how many wires but try remove on wire at a time that fuse controls. Then replace new fuse and try again.
once you think you know what is being controlled by fuse that is shorted to ground trouble shoot that for short circut with meter.
more information is neede to be more helpful
Sep 23, 2016 | Cars & Trucks
My 2005 PT Cruiser keeps blowing fuse 13, what is the problem
Fuse number 13 is a 20amp fuse that powers the ASD relay and the computer among other things.
Someone will have to pull the relay and check the circuits one by one to find the short. It could be any one of a dozen or more components.
Aug 09, 2012 | 2005 Chrysler PT Cruiser
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
The amp blow out a speaker box i went to hook a newer box and the power indicator flash on then off i disconnected all of the speaker wires thinking that may be some where there may be a short causing it...
check your amplifiers connections, maybe one has come loose, eg. the ground connection(if this is not properly earthed, this can cause a short, and blow fuses)
Hope this can help..
Aaron
Aug 08, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Keeps blowing fuses!!!
HI ..PUT AN AMP METER IN LINE TO SEE WHAT THE AMP IS DRAWING..WHEN IT IS CRANKED UP ..IS 20 AMP WHAT IT CALL FOR ON THE AMP IF SO I WOULD NOT GO ANY HIGHER.....BUT IF YOU HAD JUST USED 20 AS A STARTING POINT FOR AN AMP-AGE...SOMETIMES IT IS BETTER THAT THE FUSES BLOW ONCE IN AWHILE THAN THE AMP...ALSO CHECK FOR A LOOSE GROUND.....GOOD LUCK
Jan 29, 2009 | Planet Audio VX2002 Car Audio Amplifier
Main power fuse blows on my sansui g-5700
my Sansui G-5700 blew a fuse (i think)...where can you find fuses for this thing?
Apr 29, 2008 | Audio Players & Recorders
Always blows fuses
I would get a volt/ohm/continuity meter to test the connections. You have a short somewhere. You can take it Car Auto or Tweeter and they can check it for you. Some of these places charge a $35.00 diagnostic fee. If you have a schematic diagram, you can test where the short might be.
Apr 09, 2008 | Pioneer GM-5000T Car Audio Amplifier
Amp blowing fuses
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Nov 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
Fuse keeps blowing
NEVER EVER replace a fuse and think that va fuse will blow all by itself. The fuses are there to protect the set from catching on fire incase theres a short inside the set. Now in some cases an intermittant short can work after you replace the fuse but if its burnt black or brownish, theres a short inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifyers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted
Sep 06, 2006 | Panasonic CT-32SX12 32" TV
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
