Question about iLO (2 GB) MP3 Player
Problem with volume in player
I just bought my player today and I put some songs on it but for some reason at max volume the songs cut out a whole bunch as if the mp3 player can't handle it or something...At a volume of 15/20 it doesnt cut out at all. If anyone knows about this problem or a fix to it please let me know.
  • 8,596 Answers
Every mp3 player manual has a disclaimer that says not to play it at max volume - the only workaround is to get adjustable headphones, and keep player volume at less than max
Posted on Jul 05, 2008
SOURCE:
Song getting cut off when I download and play it
BEST SITE I FOUND FOR FREE MUSIC IS
BEEMP3 BUT YOU NEED MOZZILLA FIREFOX
look for it online and download it install it and you will get the whole song
Feb 04, 2010 | Audio Players & Recorders
Volume too low
Chances are there a limit on the volume to keep it from going to loud. If the MP3 has a screen, use it to navigate to a menu and go into it's sound settings. From there, you should be able to raise the max volume to the REAL max.
Jul 07, 2009 | Samsung YP-U3JQB MP3 Player
Battery will not fully charge
i formatted it to erase songs now it want hook up so i can put some on it did i erase the whole thing and if so what can i do
May 05, 2009 | Samsung NeXus 25 MP3 Player
My mp3 is skipping
not sure but did you convert media before you put it on your player? Some must be converted before the sync process.
Jul 31, 2008 | SanDisk Sansa c200 MP3 Player
How do I deleate unwanted files from mix max???I
You just put songs she does want on it then click shuffle it will put new songs on and delete old
Jul 30, 2008 | Disney Mix Max Digital Media Player
Problem with max. volume
Not Mac compatible largely.
ALL Mp3 players have a disclaimer telling you not to play it at max volume. Get adjustable headphones to resolve problem
Mar 26, 2008 | SanDisk Sansa m250 MP3 Player
I cant delete or add songs on my mix max
It has to make a library file of the contents on the player. It uses that file to display the titles and artists when scrolling through the menus and what not. You'll have to format your player in order to clear it up. This will erase everything and then you can put your songs and stuff back on it. Just make sure that when you do you leave at least 4 megs of space for it to make that library file. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 17, 2008 | Disney Mix Max Digital Media Player
Disney Mix Match
You may need to update the firmware on the player in order to be able to play the Max Clips.
http://digiblue.com/customer-service/faqs/disney/mixmax/14.html
As far as putting songs on the player goes check out the FAQ's page on the manufacturers website. The specific FAQ for adding songs is here...
http://digiblue.com/customer-service/faqs/disney/mixmax/02.html
Won't play certain songs
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
Playing songs at certain volume
Several things can effect the quality of your files. 1. Check your headphones by comparing them with others. 2. The file quality may be too low, you can test that by getting a higher quality MP3 file and comparing the two. 3. If you are creating the MP3 files yourself, be sure to watch the sound recording level. Allowing it to stay in the red can produce distortion while recording ay too low of a level can result in low voulume as well as possible distortions. If none of these correct the issue, you may need to replace the player.
Jun 18, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
85 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
