Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Will light and run for about ten minutes then shut down
This is a reddyheater 170T it will light run for ten minutes then shut down, pulled out the foam filter cleaned it and still the same problem....
The home heating fuel will gel thus the heater will shut down
Posted on Jan 21, 2009
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
I have a reddy heater model 170T ...Every time it starts and runs for 3 mins (app. ) Then shuts off . First the control panel, red lights , says it is a voltage problem ...now it says it is a fuel problem...
DESA bought out the assets of Reddyheater when they went bankrupt, I'd check with them for the manual. Torpedos are pretty bullet proof provided they are maintained.
A shut down at 3 minutes tells me its operating out of spec for one reason or another.
First thing is make sure your fuel is good... drain it all out, check for or crud in it, as such will raise havoc.If its clean, put it back in, if its contaminated, then get new fuel... don't run the old stuff down the drain.
Next, check the fuel filter and external air filter and if they are dirty replace them.
At this point, you need to put a gauge on the pressure port, your manual will have specs on this, and this is a mission critical adjustment. If its off, you will run too lean or too rich, and your machine will shut down in 3 minutes.If you can't get it set, it could be an air of fuel leak, or it could be a dirty inner air filter, or it could be fracture vanes at the pump. You can get a old style fuel pressure gauge from harbor freight for a few bucks to do this...
Oct 18, 2017 | Heating & Cooling
All pro heater runs for a couple of minutes.then
it only shuts down because of an overheating condition or the lack of fuel. if you have an ohm or multimeter, check the ohms on the fan and see if you have any resistance. If you do the fan is good but may still not be putting enough air across the heat exchanger to safely alloww the heater to run without causing a fire.
Dec 19, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
2002 Monte Carlo Security system has shut car down completely unable to start car
the process takes about thirty minutes. in three ten minute key cycles. here is how you do it . make sure that the battery is fully charged. step on parking brake pedal and leave it down this will keep the head lights off. turn the key and try to start it then leave it in the on position. you have to leave the key in the on position for ten minutes. you will see the security light on. after the ten minutes the light will go off then turn the key to the start position. turn the key all the way back to the off position and count to three. then try to start it and leave the key in the on position for another ten minutes till the security light goes out. you have to do this same process three times to reset the security system. sometimes you get lucky and it will start after the first ten minute cycle.
Oct 31, 2009 | 2002 Chevrolet Monte Carlo
My car wont start
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
Aug 31, 2009 | 1997 Chevrolet Cavalier
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Jun 11, 2009 | Gateway 7510GX Notebook
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
466 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
