Question about Sub-Zero 632 / S
New Sub Zero Thermost not working properly
We replaced the refrigerator thermostat in a 550 sub zero thermostat but now the temperature varies wildly. It goes from 20 to 44 to 35 etc. Checked it every few hours over three days.
Thanks in advance. . .
  • 2 more comments
  • Donald J. DeSario Jan 23, 2009
    Thanks for your reply. We installed Kit# 4200930 which is the updated one. It is the exact same thermostat that was in there that had worked for years. It had already been replaced once before years ago. I wish I still had the instruction sheet that had the modifications to double check them but I assumed that since it was an identical replacement it would be fine. Problem was definately the thermostat as it would not turn on the compressor at all at any setting but compressor would run fine as long as you had the thermostat jumped. Customer sent me his three day chart of temps showing that they varied from 20 to 44 deg. Both tubes are in the same position as they were with the one being in the bracket under the evaporator on the left and the small tube is crimped in the evaproator. Thanks.
  • Joe McG May 11, 2010
    4200930 was cut off in the first line and I assume yours was BEFORE not after like I wrote. Call factory at 800-222-7820 if you still have problems.
    Replacement Control Components (501R,532,550,561)
    Prior to #M821354/P612141. Starting with
    #M821354/P612141 see 4201260.I assume that your serial number is after that break. It sounds like you did everything right. Check the serial number break to make sure. Also check operation of your evaporator fan motor and the fan switch.
    Did you replace it with Sub Zero part 4201260? Is the bulb and cap tubes in the right place?
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
JOE LLAMA
  • 26 Answers
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
Sounds like your freezer drain is blocked up. You will require a freezer drain heater kit for this repair. It was a common problem for this unit and can be a easy fix. However it does take some patience to fish the heater down into the drain pan.
Posted on Mar 31, 2008
Hi!
I had the same problem with my 550...several times the tech came out and used a steam machine to blow out the drain...which didn't solve the problem. Finally, they ordered a refrigerator drain heater from sub-zero (part#4201290) and this finally fixed the problem. Hope this helps...I'm not a tech, just a customer. K
Posted on May 19, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
  • 1462 Answers
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
Sub Zero 550 Refrigerator Compressor runs continously?
Sounds Like You Have A Clogged In The System. If the compressor is running. The system will have to be vacuumed and flushed and re charged. Is temperature of the compressor above 120?
May 10, 2014 | Sub-Zero Refrigerators
We replaced all of the light bulbs in our 550 and the lights still do not work, any ideas?
Most likely light switch is bad. Could be light limit t-stat (prevents from overheating) and wiring problem too.
Sub-zero refrigerator repair in orange county, ca
Feb 06, 2010 | Sub-Zero Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
Sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Cycle off
As you probably know, the recommended temperature range is between 35-45 F so if you control will not allow you to set this, the sensor or associated regulator has failed.
Sep 13, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
How do i install the grille on my sub-zero 550?
Check grille springs. It should be a springs clips on the grille...
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550
You probably have a freon leak in the evaporator coil.
Nov 01, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 632 / S Logo
622 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
