Question about Sony Playstation 3 (PS3) Console
I have netgear wirless router but i hardline ps3 but i keep getting nat type 3 i need to know what ports to open on modem to get to nat type 2 can you help
    Scholar:
  • 124 Answers
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers:TCP: 80, 443, 5223 and UDP: 3478, 3479.It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, PS1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
10. Log Out of the Router Page.
Posted on Apr 07, 2010
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
Needs nat type open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 05, 2011 | NetGear DGN2000 Wireless Router
Can I change the Nat type? Can't figure out how to change it from type 3?
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Cant get full online with ps3
PS3 and Xbox ( NON BELKIN)
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jun 17, 2010 | NetGear WGR614 Wireless Router
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
Need nat type 2-PS3 Cable ISP digital phone modem wireless route
you can put your ps3 in a dmz zone. if still does not work its not your router. u can keep your ps3 in dmz and get your router to open ports. u can call your router company. If still does not work its not your router more than likely. It might be your modem. i have at&t and that was my issue. i went to dmz on modem and allowed it to pass through dmz zone and ip addresses to pass through. but make sure on your comp u have spyware or something. Your ps3 can not get virus.
Sep 06, 2009 | Netopia (3347NWG-VGX) Wireless Router...
How to get nat 1 netopia router 3347 ps3
  • you need to access the router access page of the router, look at the bottom for router access page or call router support
  • then go to WAN setup to enable/disable NAT
Aug 11, 2009 | Netopia (3347NWG-VGX) Wireless Router...
My ps3 HAS A dns problem
Whenever you are dealin with a DNS error, it is a problem on your internet service provider's end. Contact them for a solution. Thanks
Dec 31, 2008 | NetGear WGR614 Wireless Router
Ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Jul 15, 2008 | NetGear WGR614 Wireless Router
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
