Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
Whirlpool washer has four selections: hot wash,cold rinse; cold wash, cold rinse;warm wash, warm rinse; and sensor cold wash, cold rinse.
hot water is getting to the washer- have warm wash, warm rinse - but not hot when switched to hot - only cold comes out and flow is same.
Does mean the switch is bad?
  • rosefoor4 Jan 18, 2009
    LSQ9549PW2
  • Anonymous Mar 24, 2014
    only when using warm wash
  • 66 Answers
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
When washer fills on warm water mode, it alternates between cold and hot water coming out in spurts. Is this normal, as it doesnt do it on rinse cycle.
yes its normal the reason it does not do it on rinse is that only cold water is used to rinse not /hot warm
please rank this advice if it helped
thank you
Dec 28, 2010 | Maytag MAT13MN Top Load Washer
2 problems
Sounds like the selenoid valves are backwards. Or the water hooked up backwards. Or actually like the cold water one isnt working at all. Either the selenoid or the screen stopped up. Even on cold water i noticed that some washers use warm. But all of them uses cold water to rinse. At least the last rinse. So when it uses cold water there isnt any. First of all, Switch the two wires with each other and wash on hot and see if cold works then. If not Take the selenoid out and apart then clean the diaphram real good with soap and water then pup back together.
May 31, 2010 | Maytag MTW5600TQ Top Load Washer
Whirlpool washer new..,. washes cold wash cold rinse.. hot wash cold rinse.. but on warm wash is cold wash cold rinse I can send wasdher back just got it t0 day or is there something I can do?
Be sure the hot water valve is all the way opened first. Both faucets must have equal pressure for washer to work properly. They all rinse with cold water, this is normal.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
ZANUSSI ZWD162701 washing always comes out cold - WHY?
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Zanussi ZWD1270 Front Load Washer / Dryer
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
571 people viewed this question
Dan Webster
Dan Webster
Sal De
