Question about Hitachi 53UWX10B 53" Rear Projection Television
Blue and yellow outlines
The tv started having blue and yellow around the edges of the people etc.
    Genius:
  • 1,139 Answers
Hello steveandlill,
I posted this before, however I believe it fits your problem too:
You have a convergence amplifier problem. This is a common problem inthese types of televisions. The fix for this problem is to replace thetwo convergence amplifiers in your tv. These amplifiers usually go badalong with the associated bias resistors. I would suggest that if youare going to do this yourself you should use only the manufacturerecommended replacement parts. There are many who will tell you toupgrade the amplifiers, but my experiences have told me this is moretrouble then it is worth, if you don't plan on redesigning the circuititself. So with that being said, here is the basic procedure:
1) Get a schematic for your set (to be used in parts location and alignment instruction)
2)Using the Schematic locate the STK329-xxx or STK392-xxx seriesamplifiers (They are the two large six sided components attached to alarge heat sink on the deflection board)
3) unplug the TV set
4) remove the deflection board from the TV set
5)using a soldering gun or iron with either a de-soldering pump orde-soldering braid remove the solder from the pins of the amplifiersand the associative biasing resistors.
6) remove the amplifiersfrom the heat sink and clean the heat sink off with alcohol or asolvent designed for removing the silicon paste.
7) coat the metal plate of the new amplifiers with heat sink paste and install them on to the heat sink.
8) install the associative biasing resistors
9) solder all of the components, making sure not to create solder bridges (short circuits) on the printed circuit board.
10) inspect the soldering job for bridges and cold solder joints (touching the joins up if they are cold)
11) reinstall the board to the television (reconnecting all cables removed.
12) power up the TV and perform the alignment instructions in the schematic
13) set the alignment of the TV
14) perform the magic focus setup
This should complete this task.
Now if you feel that you can not do these tasks, please consult a qualified TV technician about doing this for you.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 19, 2009
Samsung la40a450c1d
It sounds that the backlight to this TV have some fault. Might be of weak CCFL lamps. Contact any service technician.
Jul 22, 2013 | Televison & Video
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
Original installation color flared up around edges and outlines
what she tried to sell her was and HDMI cable for hi def signal between box and tv. now with what your describing sounds like panel solarization. if you can send me a pic i could better verify your problem. sent pic to support@cats-inc.us
Apr 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The picture looks like a bowtie and red blue and
TURN YOUR COLOR OFF.IF YOU SEE THE RED,BLUE AND GREEN AROUND THE EDGES EX.SOMEONES FACE YOU CONVERGANTS IS OUT NEEDS RE LINEMENT.
Apr 24, 2010 | RCA Televison & Video
Yellow and blue shadows
You can try adjusting the convergence which will be in the Advanced Menu of your TV. If it will not adjust properly then you need to have a qualified technician repair the set.
Jan 29, 2009 | Mitsubishi WS-55513 55" Rear Projection...
BLUE AND YELLOW
If you go to the following link we have the service manual for your set for 10.99 and we offer unlimited chat support to help you diagnose and repair your set. Just click on the panisonic link. If you click on the contact us link and provide your email address we will email the manual right out to you along with instructions on how to enter into chat with us. I am one of their support Techs. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Yellow/blue outlined image while viewing
reset the settings to factory default. the resolution and phase is off. also make sure the projector is not too close to the screen.
Nov 29, 2007 | InFocus LP 735 Multimedia Projector
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
62 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
