Question about Frigidaire FEQ332E Electric Dryer
My frigidaire dryer only blows cold air
My dryer is only 3 years old and I already had to have the Rear bearing replaced and now it only blows cold air. What is wrong with it and Can I fix it myself?
Gretchen
  • gretchen_ini Jan 16, 2009
    Thank you soo much. I have a tech coming over tmro and I just wanted to know what he was going to find.
    Thank you again for your help.
    Gretchen
  • 334 Answers
You either have a tripped safety switch, a burnt element, or a burnt/loose wire to/from the element and or safety switches/controlls.
If you are handy, and have the tools, it should be a fairly easy repair.
You will need a volt/ohm meter to check the element for continuity, the safelty limit switches for continuity to lacate which part is the problem. (some switches are push button resset, some are one time trip and must be replaced.
The second issue is what caused it to quit in the first place.
The #1 cause for that type of failure, is lack of airflow due to a clogged vent pipe.
Make sure the filter, dryer outlet, pipt and outlet from the house is all clear from lint, birds nests, kinks etc.
Posted on Jan 16, 2009
Replace bearing in a GE SXH47eg1WW dryer
The bearing is the plastic which holds the front glides. It just snaps in place and is easy to remove using flat blade screw driver. The bearing has 3 or four glides which are purchased separately. The rear of the dryer also has a bearing which is plastic part number WE3x75 on the old models, newer models use a different number.
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gib
Apr 14, 2014 | GE Dryers
I ust replaced belt/tensioner/front upper and lower felt and rear bearing and clean vent out still have a vibration/ humming noise could noise come from exhaust blower ?
That is exactly what it is. Frigidaire dryers are known for the bearing wearing down and causing the vibration. Here is the new blower you need.
Don't forget to move the thermostat over from the old blower to the new one!
Oct 19, 2012 | Frigidaire Dryers
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
Dryer works but is only blowing cold air. just bought the dryer last year and have already had it repaired once.
my Samsung was in a flood(so solution may only apply to floods), changed heater assembly, still blowing cold air, turned out to be the little black box on the generator, took box cover off,cleaned the connectors in box and voila...instant heat
Nov 28, 2009 | Samsung DV448AEE Electric Dryer
Clothes get hung or catch in the dryer and buttons get torn off or the clothes sometimes get scorched. I have a 2 year old Frigidaire front loader. Model # LEQ2152EE0. Any advice -- other than buy a new...
I believe your problem is worn out drum glides. You should examine the drum to see if the paint is not worn off where the glides make contact. A loss of coating there will accelerate wear on the new replacement glides. Also the bearing at the rear of the drum should be inspected and replaced if worn, or re lubricated if serviceable. The bearing should be a simple ball and socket assembly.
May 19, 2009 | Frigidaire Dryers
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Frigidaire FAH106N1 Thru-Wall/Window Air Conditioner
Check for blockage of the air pathway. Check that the fan turns freely, as the bearings or bushings could be shot. The fan blades could also be loose. You might just want to replace the fan, as it is cheaper than replacing bushing/bearings.
Jul 07, 2008 | Frigidaire FAH106N1 Wall/Window Air...
Frigidaire FEQ332E Electric Dryer Logo
201 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
