Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
Mitre saw won't cut square
I have a 15 year old craftsman mitre squuare. it works like a mule but when I use it to cut a compound angle I can not get it to cut regular mitres square. When I cut a mitre the bottom of the angle is open. I have tried to zero out the saw but it seems that zero in dicator must be mis alined. Any help would be greatly appreciated.
  • David Ford
    David Ford May 11, 2010
    can you please furnish a model and brand for this tool. The header says Bosch but you say craftsman. Let me know and I will see what I can do.
Look on top of fence
see 4 holes
loosen 4 bolts (probably hex wrench) and fence will loosen also
framing square against loose fence and lowered blade (to re-calibrate)
tighten fence,... square to blade
Posted on Dec 04, 2011
  • 33 Answers
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Posted on Feb 13, 2009
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
How to mitre corners
using a set square , The angle if 45 degrees is machined into the handle draw a line at 45 degrees across the surface you wish to mitre cut
clamp a piece of timber along that line and use it as a guide to cut with the circular saw
Apr 27, 2016 | Saws
Mitre saw cod211lsm
Few budget tools and especially generic, brand engineered tools imported from the far east are superbly accurate but tend to be "near enough".
You didn't say whether it is a hand operated mitre saw or a power saw.
Most power mitre saws have a number of stops that can be adjusted or filed in order to calibrate the angles and this process should be done when the saw arrives. Once both 45 degree angles have been calibrated accurately the angles in between should fall into place fairly well.
One problem with low cost mitre (chop) saws, even some so-called professional saws is the construction is so light, when pulling down the handle the machine flexes and spoils the cut. This is especially true when the handle is not set exactly in line with the blade or when not paying full attention when making a cut.
Having experienced such saws I have learned much about them so when I visit a tool store I examine their stock by twisting, rocking and pulling the saw heads and the amount of movement in many new saws of popular brands is disgusting, even some pretending to be premium brands. So far only a few of the most expensive types have impressed me.
That doesn't mean the others are unusable and with care fairly accurate cuts can be made when a suitable technique has been developed - like using a rifle with bent sights...
Nov 27, 2017 | Tools & Hardware - Others
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I have an old Craftsman 9 inch table saw that will not cut straight. When you set the fence and get evrything ready it cuts at an angle. A 1x4 will not cut straight it always cuts at an angle. Is there a...
unplug the saw then:
turn the saw over or, get under it; there is a long bolt that sets the
saw motor tilt two nuts jam lock it; release the nuts and adjust the saw using a t-square for 90 degrees.
Jul 31, 2010 | Craftsman Saws
How to build a wooden pyramid frame for school children, 2metres on each length of base.
cut 4 pieces of 2x2 to1.5 inches short of 2 metres. lay them out end to end to form a two metre box. it can only work one way. then take string from corner to corner to find the center, making a crosshair. then stand a level rod at the centre to the desired height and fasten equal length lines from each corner to the peak. using a compound mitre saw, place an angle finder at the bottom and top corners to give you the angle to cut your piece with the saw set at 45 degrees, to give you your compound miter for the top. just set the saw blade to line up with the angle finder to get the bottom cut. the length of your "tight" string line frome corner to peak is your length of "hip" piece
Mar 10, 2010 | RTO M-D Building Products Carpentry &...
Looking for help scouts have a carpentry merit badge from the 50s they talk about using a BEVEl and a Miter tools can you help
The bevel is an angle fiding tool. it consists of a wooden section about 4" long with a swivel bolt at one end connected to a slotted metal blade (similar to a 1 foot steel ruler). The bolt has a wing nut and bolt to allow loosenig to allow the blade to rotate and slide to the required angle where it is locked into position using the wing nut.
The mitre is a wooden block with slots cut into it at pre determined angles. ie 45 degrees. When cutting a mitre joint the wood is placed against the block and the saw follows the line of the slot cutting the 45 degree angle.
Hope this makes sense and good luck
Feb 18, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
How do you adjust the saws angle cut? When it is sett at 0 degress it is not making a square cut.
take a framing square sit it on base plate and adjust till its square and level with that angle.works same with table saws also hope that helps ya
Nov 28, 2009 | Hitachi C12LSH 12" Sliding Dual Compound...
Why when i cut a bit of 6" skirting board it does'nt cut square on a brand new ryobi ems 2026 sliding mitre saw
Don't ever assume that the markings on the angle setting are correct and accurate. Always check squareness with a square before you use a miter saw. With almost all brands of power tools being built overseas nowadays there is unfortunately a question of accuracy on most brands. Always check.
Mar 16, 2009 | Dewalt Mitre Saw Workstation
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
1,180 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
