Question about KitchenAid KHWS01PMT Front Load Washer
I HAVE A FAULT CODE F 11 AND DL F
Right now I can't get the washer on . When I hit the control on button, select an cycle it doesn't turn on after a few seconds the fault code dl f comes on....For the fault code f 11 that comes on right before the spin or rinse cylce please help Been like this for a couple of months for the f 11, just a day for the dl f code
  • 5 more comments
  • Anonymous Nov 22, 2007
    THE SEMA PROBLEM
  • Anonymous Feb 11, 2008
    Exactly the same problem
  • Anonymous Feb 24, 2008
    I thought F DL meant failure door lock. That is the way I was going to tackle it. Would that be a waste of time?
  • gaz2 Jun 01, 2008
    got fault code f11 on whirlpool AWM8123/1 washing machine, anybody know what this is ?
  • Yvetta Watson Jun 15, 2008
    In the begining I too had the DL-F code. Had the repairman out to fix it. (expesive too)!!!!! Now I have the F-11 code. The unit works fine untill about 1-2 mins from the end of the final spin cycle. I used to be able to get it going again by hitting the canceal button until it stops flashing, & it reads back to the last 1 or 2 mins left. From there I then push & hold the start button (about 5sec). Wait another 5sec, then I hear a click & it starts up right were it left (stopped) off. But, today (6-14-08) it will not even do that. It just will not click & start. Now it will just start beeping AGAIN, untill I hit the canceal button, like I was going to repeat the same steps AGAIN!!!!!!!!!
  • MNMWNUTZ Dec 18, 2008
    WE HAVE THE SAME PROBLEM. HAS HAPPENED 2 OR 3 TIMES WITHIN 1 WEEK, ABOUT TO CALL FOR SERVICE ANY SUGGESTIONS
  • nickle28 Dec 28, 2008
    I have the same problem and this is the 3rd time we have had it fixed in a year! I am really disappointed with this washer.
    Problem Solver:
  • 12 Answers
Here is more information on this problem, and how to fix it yourself.
http://adsisecurity.com/KenmoreWasher.htm
Posted on Nov 20, 2011
Chances are it is the slightly corroded connectors. Remove the top lid. Carefully label/record the connectors to the control unit at the back. Remove it completely. Be sure to ground yourself first to eliminate static shocks. Remove the printed circuit board and just "clean" the connectors with a pencil erasor.
Posted on Jan 24, 2009
We have had the exact same problems, f-11 code, f-dl code have had repairman out 3 times and they replaced the door lock actuator, works for a week and then the same thing all over again
Posted on Sep 07, 2008
I thought F DL meant Failure Door Lock. That is the way I was going to tackle it. Would doing that be a waste of time?
Posted on Feb 24, 2008
  • 35 Answers
It looks as if your having a communication problem between your central control unit and your motor control unit.check wiring connection between these two components.if wiring is ok then you will have determine which of these components is malfunctioning.you can also remove kick plate and remove service manual located on either side at bottom.this should give you some help.
Posted on Jun 30, 2007
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
    Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
    Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
    If you still face the problem then follow the procedure:
    Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
    Plug the washer back in and press [Power] to turn on the washer.
    Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
    Press [Start/Pause] to begin a drain only cycle.
    After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
    This will remove excess soap suds and light residue from the drum.
    Repeat this step until no visible suds are in the drum of the washer.
    Hope this helps.
    Shane
    Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
    My washer is not starting in the selected mode. It had a fault code of "dL" which I figured means there is a "door lock" problem. Is this correct and can it be fixed by me? Please help, Thank You
    DL error stands for Door Lock.Follow the instructions to repair yourself.
    Step 1
    If your door hasn't yet locked and will not lock simply press cancel and try again.
    If this will not work and the cycle still will not start up then skip to step three.
    Step 2
    If your door is already locked and you get an "F" error press and hold the cancel button and select drain/spin.If this still doesn't work and your clothes are trapped inside do not resort to getting out the crow bar and a sledge hammer.You can manually unlock the door by following these steps:
    - Unplug washer or disconnect power.
    - Remove the lower kick panel.
    - Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
    - Located on the bottom of the door switch/lock unit is a teardrop shaped tab.
    - Gently pull the tab down about a 1/4˝ or until a click is heard.
    - The door may be now opened.
    Step 3
    If your door fails to lock and your cycle will not start moderately but forcefully hit the back right hand corner of the washer with your fist.You may have to do this a couple of times,but you should hear the locking mechanism click so your washer is now locked.
    Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore elite HE4 has fault code of dl and F?
    F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
    Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
    F-11
    FIRST COMMENT
    F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Possible Causes / Procedure
    1. Unplug washer or disconnect power.
    2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
    3. Check the drive system for any worn or failed components.
    4. Plug in washer or reconnect power.
    5. Verify CCU operation by running a Diagnostic test or any cycle.
    6. Check the MCU by looking for operations of the drive motor.
    7. Check the drive motor for powered rotations.
    8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
    Replace failed component.
    Jun 15, 2008 | KitchenAid KHWS01PMT Front Load Washer
    Washer displays DL error
    The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
    Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    KitchenAid KHWS01PMT Front Load Washer Logo
    644 people viewed this question
    Top KitchenAid Washing Machines Experts
    kj henriksen
    kj henriksen
    gbob59
    Mike
    Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
