Question about Samsung DVD-V4600 DVD Player/VCR
Vcr/dvd won't play
My tv only works on channel 4 but it appears my vcr/dvd combo only works on channel 3 or I can't figure out how to put it on 4
  • 1,199 Answers
You may have to buy an RF modulator ($20.00 at any radio shack or wall-mart) this will allow the hook up to work! ( has a channel 3 or 4 selector switch!)
I hope this is of big help!
Please rate answer
Thank You!
Posted on Jan 16, 2009
How do i set the out put channel on a broksonice dvd/vcr combo
Turn off the combo. Press and hold the number 3 or 4 on the remote. When 3rf or 4rf appears in the display on the combo, the output channel is set.
Jun 30, 2011 | Broksonic DRVCR900 DVD Recorder/VCR
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
How can i put the code?
Mar 19, 2010 | One For All URC-3021 Remote Control
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Plays on wrong channel
ok i downloaded and read your DVR-1000 manual , this is what you will do .
While the DVD+VCR is turned off, press and hold CHANNEL (up/down) button on the front panel for about five seconds.
The unit will turn itself on and “RF 03” or “RF 04” appears on
Use CH ( up / down ) button on the front panel or CH ( up / down ) button on the remote control to change the RF output
channel (CH 03 or CH 04).
Turn the DVD+VCR off and then on
Set the TV to channel 3 or 4 depending on the RF
output channel you selected.
Now you can watch the DVD+VCR playback on CH3
or CH4 of your TV
PS , you should see a child lock button on the remote , if you press that button , you will disable front panel button controls so kids can't change anything , press it again to unlock that feature , it might come in handy.
Thanks for using Fix Ya .
Jan 23, 2009 | GoVideo Go Video DVD/VCR Combo
Magnavox 2205 DVD/VCR Output Channel Control
1: set tv to channel you want your vcr output to be on. 2: turn vcr on (if it is a vcr/dvd combo make sure it is on vcr) 3: put in video tape. 4: press play button one time, release it, and then press and hold it for three to five seconds. i had to call customer support to figure this out on mine.
Jan 17, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
Nov 02, 2008 | Televison & Video
Setting up the chanel on the VCR
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
