Question about Microsoft Xbox 360 Console
I purchased a 50 inch hd rca my lamp has burned out and i purchased the two year extended warranty how do i get a new lamp bulb so that i can put it in email me or call me at 256-502-9498.
  • 142 Answers
Call the company in which you purchased the warrunty from.
Posted on Jan 16, 2009
My amish heat surge heater has to bad bulbs in it. I found that the heater is not putting out heat. the fan works but it won't heat. Is it because the bulbs are burnned out?
Sadly, the only thing that is Amish on your heater is the cabinet mantle. The electric fireplace is made in China. Never-the-less, from what you describe, it appears that the heater coil is not receiving power or it has burned out. If it's not receiving power, one of the resistors that controls the power to heater has gone bad (probably melted). The bulbs being burned out does not affect the heater. You must have had this unit for sometime for the bulbs to burn out. Normally these are LED Bulbs that have a tremendously long life. It may be that the bulbs have vibrated loose and need to be re-tighten.
If I recall correctly, these units were sold with a one year warranty and may have had an option of an extended warranty. If yours is still under that one year warranty, you're in business. If you purchased the extended warranty, that's even better.
In any event, contact their customer service dept @ 1-800-924-7964, as they may able to help you even more.
Jan 19, 2011 | Heating & Cooling
I have a 50 inch widescreen LCD HITACHI and it needs a new lamp. How much would that cost?
Google the model number with the word lamp after it---price ranges from 79 for just bulb and from 124 for bulb with housing (cartridge)
Do some shopping and I suggest the one in a cartridge as if you buy just the bulb you have to take the old housing apart and install it.
Shop warranty as well, some of these are 90 days and some much longer warranty.
If this information helped you rate this free solution as very helpful as I do this for free.
SD TECH
THIS IS THE LAMP WITH CARTRIDGE
Aug 22, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My rca dlp doesn't turn on
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Poor quality color with mostly green tones
Optical Block in your TV is going bad. If you don't have any extended warranty - It is pretty expensive repair and is not worth of fixing it in most cases.
Mar 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Sams club warranty problem
The bulbs aren't normally covered after the first year. Some extended warranty companies used to cover the bulbs after that, but now since the economy is bad... a lot of companies are trying to save money by not covering the lamps anymore. And the ones that did are handing the warranties over to other companies. You probably will just have to buy one yourself or you will just be chasing your tail.
Jun 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Turn tv on, sound comes on but no picture, power light blinks,
The clear bulb located back left side needed to be replaced. Too much heat causes the bulb to burn out. Simple fix. One screw to open door to bulb compartment. Two screws to remove bulb assembly. Thank goodness for extended service warranty which paid for it. This is the second one in three years. At the price of $200 for bulb and $100 for trip and labor, this is not an inexpensive fix. Anyone purchasing a projection tv should get an extended warranty.
Apr 08, 2009 | RCA P61940 61" Rear Projection Television
New HDTV bulb
I have just bought a second hand Sony 50 inch Projection & the owner from new (paid 1200 Quid) assures me he has never replaced the bulb in 6 years. Don't pay 190 Pounds plus, if you can loosen 2 nuts you can get an Osram bulb alone (not mounted) for 32 Pounds 55 Dollars delivered if you search well on E Bay
Jul 29, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Buzzing noise, still have good picture
it's the colour wheel,i have replaced it once under warranty and now need another, rca and dlp ****
Jul 18, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Projection lamp burn out
well look at this,, I use many projectors due to my work with artist and my bussiness in wedding and happybirdays,I have to chage those expensive lamp frecuenly. a cople of time the lamp fuse off rapily in short time and the store is ok no buddies warrant electric or electronic parts so we the custumerpay for the in line manufacture bad parts so nothing to do buy another one and thats all you can do but clean the soket and allway look for crack or weare parts in the socket I use to inspect everything in the lamp system specialy the socket and clean the contatc were you conect the lamp with a very thinn sharper tool if you suspec change the lamp socket they always work at verry high temperature ....good luck and rate me
Jan 05, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Bulbs keep burning out
I would try a genuine sony replacement lamp. There are some reputable sellers on ebay selling them for a couple hundred dollars...Oh also, you say your TV is under warranty?
If it is under Sony's factory 1 year warranty, I would call them direct. If your on some sort of extended warranty plan, through a 3rd party company, tell them you want the genuine sony bulb. Put up a fight, and if that doesnt work, read the fine print for your 3rd party warranty. My extended 3rd party warranty states that if the TV fails 3 times during the extended warranty period, they will replace it with a new one as per their "Lemon" policy.
Sep 22, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
