Question about Kenmore 659 Electric Dryer
Dryer stopped getting hot - is it becasue it is -24 deg. outside
Dryer
  • jusafog9 Jan 17, 2009
    My dryer has stopped getting hot . I have cleaned out the lint hose. I tried getting the back off , but I cannot figure it out.
    Once I do get the back off, what do I need to trouble shoot?
  • 68 Answers
It wouldn't be the temperature outside. Might be the thermostat.
Posted on Jan 16, 2009
A/c works great at 75 deg.outside ,above 75 deg. works for short time starts blowing hot air i have did repair added 134,to it but same thing????
My personal suggestion
would be to go for these repair catalogs. I know this website www.reliable-store.com that i used to buy them from, and they sold online it was very good manual. Go ahead, I bet.
Mar 07, 2018 | 2001 Dodge Ram 1500 Truck 2WD
Dryer gets hot on the outside of machine
Clean the lint out of the pipe that goes out side, also the grate on the outside, If that dosent do it take the back off and see where the lint comes out, take that apart and clean the lint out. I have had this problem before and just recently. The dryer has a saftey fuse, when the dryer gets too hot to shut off, thats why your clothes are not drying. 1st try the pipe that goes outside including the end(outside).
Aug 15, 2012 | Kenmore 400 6942 Dryer
Why does the outside of my dryer get so hot? Also, why does it not stop running when i open the door? I have to turn the cycle off and then open the door,
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 08, 2011 | Kenmore Dryers
During heating (outside temp. 2 deg C), outside
Get the charge tested, check the sub-cooling across the outdoor coil.
Dec 19, 2009 | Heating & Cooling
When it gets hot it stop and then start again when cooled down
This problem is usually caused from restrictions in the vent hose and the unit getting to hot causing the limit control to shut down until it cools. Check your filter, your dryer vent line for obstructions and the outside for pieces of lint plugging it and slowing the air flow. I have found lint build up in the line, at the base of the dryer where the exhaust line connects, and in the exhaust mounted on the outside wall.
Oct 09, 2009 | Kenmore 63942 Dryer
Dryer gets hot runs for 10 min, then cools off
Make sure the hot air vent to the outside is clean and has no more than two 90 deg bends in it.
If the vent tubing is restricted, the system will shut off the heat source to prevent a fire.
Make sure you take it apart and thuroughly clean it.
Good luck.
Regards,
Jul 04, 2009 | Dryers
Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
May 26, 2009 | Kenmore Dryers
Car stalls when you come to a stop when car gets hot
i would have your idle air control solenoid replaced and also check for vacuum leaks.thank for the question
Jan 30, 2009 | 2003 Ford Focus
Dryer runs at 120 deg tops
you can install a higher temperature cycling thermostat. They normally have a 140* cycling thermostat. Make sure heat element is not broken. Some models have a double element hand only half will work. post make and model
Jan 14, 2009 | Kenmore 60172 Electric Commercial Dryer
Chevy van
your ign timing is to high you need to rotate your distributor clockwise about 4 deg.
Jun 27, 2008 | 1989 Chevrolet G30
Kenmore 659 Electric Dryer Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
