Question about Magic Chef Microwave Ovens
Microwave stop working ( no heat )
The microwave power and other function are working, but there is no heat.
    Genius:
  • 1,199 Answers
This is a sure sign that the magnatron has burnt out and needs replaced! (this is the part of the oven thar cooks the food!
Please rate my response!
Thank You!
Posted on Jan 16, 2009
CATA MC25SS microwave not heating
Usually when a microwave's fuse blows, it will be dead, not partially functioning.
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
Feb 25, 2013 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Power is fine but it stop heating as disired ? display , time function all working but no heat ?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ]
[][]0-=-=
Apr 10, 2011 | KitchenAid KCMS145J Microwave Oven
After a recent power cut my Kambrook Microwave has stopped heating. All the other functions seem to work, just doesn't heat the food ?
check the thermal hv fuse located near the transformer or check its continuity from line source
Feb 24, 2011 | Microwave Ovens
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave runs and has functional control panel, but no heat.
The controler board, or the power supply for the magnetron has probably failed, or a safety switch is not working properly. It is also possible that the controler board is in a protect mode because of a defect.
The magnetron uses very high voltage at very high current. There is a very large capacitor in the power supply for filtering the DC for the magnetron. This area of the microwave oven is very dangerous to work on. The power supply can be lethal if proper procedure is not complied to when working on it.
I strongly suggest that you do NOT attempt to service this yourself, unless you have the proper training, test instruments, tools, and service manuals to work on it.
After servicing, the tech is supposed to verify the operating power level, and do an EM (ElectroMagnetic) radiation leakage test. This is important after servicing this type of appliance.
Take the microwave oven in for an estimate. From this you can make an intelligent decision if you are going to have it serviced or replace it.
Excellent article about microwave ovens:
http://www.betterhealth.vic.gov.au/bhcv2/bhcarticles.nsf/pages/Microwave_ovens_safety_issues?Open
Microwave Oven FAQ from GE:
http://www.geappliances.ca/faq/faq5.jsp
Jerry G.
Apr 14, 2008 | GE Spacemaker Over-the-Range Microwave
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE OVEN
Bad power diode, bad power capacitor or bad magnetron
Google on 'microwave not heating' and you'll get some sources of information
Dec 13, 2007 | Microwave Ovens
Microwave Ovens Logo
83 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
