Question about Whirlpool Calypso GVW9959K Top Load Washer
Load knocking sound
During one of the wash cycles the washer makes a very load Kerr Bonking sound It sounds like and old John Deer Tractor. It seems to be getting loader. Help!!!!!
  • Sunny711 Jan 16, 2009
    I have the same problem and then it stops and the code CA comes up.
  • Anonymous Jan 19, 2009
    Mine is not the load balance when the drum is empty it does this. Looks like to me the steel drum is not centered in the plastic retaining tub. I have leveled the washer unit and it continues to rub the top ring cap. The rub had put a hole in the ring and the ring was holding water. I have fixed that by drilling holes in the bottom of the ring so that the water that gets in there can drain. I don't know how to get the steel drum to center itself in the plastic retaining drum to keep the ring from rubbing the plastic cap. Eventually the plastic ring that sets on the steel drum is going to wear away because the cap continues to rub the ring.
    Sergeant:
    Champion:
  • 239 Answers
Out of balance,or the clothes are not even spread and causes one side to be heavier
Posted on Jan 17, 2009
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
While spinning makes a knocking sound
is that a top load or front load washer?
Feb 28, 2014 | Whirlpool Washing Machines
John deer it 150 knock when it gets load on it get worse hotter it gets take load off it does good
How much load? Any small engine will lug when at it's limits and make a knocking like sound.
Sep 07, 2013 | John Deere Garden
Washing machine knocks and dims lights only during rinse cycle
Possible that the bearings are a suspect, if the machine seems to wobble around. Also if the load is high, does the noise go higher, if so check the suspension, check the mounting and the counter weights.
Please check this link: Wobbling machine
Jan 24, 2013 | Washing Machines
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Knocking in trany during agitate/wash cycle
Probably a bad tranny or bad bearings on the tub.
Mar 12, 2010 | Washing Machines
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal De
