Question about Sony STR-DE945 Receiver
My Sony DE 945 Blue LED light indicating digital audio reception
The Blue LED no longer lights and the AFD decode feature no longer works. I still have the DVD player and the HD Sat receiver connected via Fiber Optic "Monster" cables and the sound works, but the auto decoding feature no longer works. Any ideas?
Does anyone have a solution? The authorized Sony repair center in my town is stumped.
Posted on Jun 03, 2010
Multi channel decoding blue light not working yet?
Multi Channel Decoding will only work when you have it briamp.Meaning to have a sepperate power amp hooked up to it for your fronts,Rears end Centre, Speakers, Witch sony is to stupid to tell you that in there owners (Manaul)
Oct 21, 2012 | Sony STR-DE545 Receiver
I'm going to surround sound mode, and my rear speakers are not working. I do a tone test, and they def work, but I can't get them working right?
Since you seem to be having problems with 'simulated' surround, how does ACTUAL surround material behave?
Have you tried AFD with certifiable multichannel source material to verify the surround speakers receive programmed sound??
Do the Dolby Digital or Pro Logic indicators light?
What about the other modes?
Mar 20, 2010 | Sony STR-DE475 Receiver
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Owners Manual for Kenwood Car radio Model KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
I have a sony str-db940, since it came back from being repaired, it reports 'not in use' when the 'sur' button is pressed and won't decode surround sound. Any ideas?
Check if you're using the digital cables like optical cable to get the audio from the receiver. If yes, please select the Input mode to AUTO by pressing the mode button repeatedly. If you're using a analog cables, please try to change the sound field and check. Press the A.F.D button repeatedly to change the sound field and try. You can also try connecting a different audio source like Cable box, dvd player and check the issue.
If the issue persists, please reset the receiver. To reset the Receiver, turn OFF the unit and press n hold the MODE + button and Power button till S.F Initialize appears. If the issue still persists, you may be having 90 days warranty after the date of repair or original warranty which ever is longer. Contact sony to resolve the issue.
Sep 26, 2009 | Sony STR-DB940 Receiver
Getting a digital output from a Blue Ray Player optical out
Check the audio settings in the blue ray audio menu.
Jun 19, 2017 | Sony STR-DE685 Receiver
Sony STR de845, 5.1 Surround does not work. 3.2 is indicated o
3.2 IS the "5.1" mode for this receiver. 3.2 is indicating that you have 3 front channels and 2 rear channels. The ".1" is applied to all the speakers (LFE). If you read the manual on page 37, you'll see that "3.2" is displayed with either "Dolby Digital 3.2" or "DTS 3.2". The little icons of the speakers in the display window will show you which channels are active. The bottom line is as long as you see the blue light, it's decoding multi-channel discreet surround sound (at least 5.1).
Nov 22, 2008 | Sony STR-DE845 Receiver
Sony STR-DA5000ES 7.1 Receiver
its for digital decoding of the sound source. You need to connect a digital cable (ie optical) from the DVD player to the optical input in the receiver. The receiver should then decode the source into multichannel components ie 5 channels for example
Jul 23, 2008 | Sony STR-DA5000ES Receiver
Only decoding in pro-logic
go in blue ray dvd menu as dvd is playing and select the audio out formatt u wann use has to be on 6.1 or least 5.1 digital not 2.o ch ok and u may be seding the digital with the hdmi outs not both be hard for it to do doe syour tv had digital opti out run that to reivciver on digital input ok tell blue ray options menu also digital oput bitrate ok
Jan 18, 2008 | Sony STR-DE835 Receiver
Sony V555ES Amp:
Try setting your amp to "auto format decode".
It should easily be heard in this mode.
The sub will not show up on the display when in 5.1 mode. (Blue light on)
Use this with music, and use the 5.1 with movies to get a better experience from your amp.
The sub will work in 5.1 but doesn't show up in the display. Try movies with loud sounds.
Most of the pre-set sound fields are of no use to me. I only use normal surround, and AFD and love it. I hope this works for you!
Jul 03, 2007 | Sony STR-V555ES Receiver
Sony STR-DE945 Receiver Logo
277 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
