Question about SanDisk Sansa c200 MP3 Player
Sansa c200 will not connect to computer via USB
Sansa turns on but stops at start up screen (the one that is mostly white with the red streak through the middle with SanDisk written in the red and the Rat with the mp3 player in its body) and will not go any further. When I plug in the USB cable windows XP says the USB device is not recognized, says it has malfunctioned) I have tried resettingvia power button, holding the volume button, holding the rec button, nothing gets it recognized by the computer. I have a second one and it works fine with the existing cable so the cable is not the issue. Any help before I chuck this damn thing off my deck into the snow??
  • 159 Answers
Try add new hardware wizard.
Once it does not find it.
Tell the new hardware wizard to search for MTP device.
Posted on Jan 16, 2009
How to delete the recordings??
The easiest way is to connect to your computer via a usb cable. Click on the local disc "E: or whatever yours is and do it on line. Remember to use the safe disconnection procedure.
Dec 30, 2009 | SanDisk Sansa c240 MP3 Player
I turn it on and the screen is white.
when that happen to me i held the power button and the middle button at the same time for like 15 sec then it turned off  try that  then turn it back on
Nov 09, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa device is not displayed on my computer
If it is connected to the PC, then this is normal.
If it is not connected to the PC, reset the device.
Here is a link to your user's manual: which shows you the reset:
http://www.sandisk.com/sansa/assets/English/products/c200/c200_userguide_en.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sandisk sansa c200 is frozen at the "sandisk" screen!
Unplug unit from Mac.
do a restart with windows puter
Plug unit into windows puter USB unit
If the c200 is recognized you're good to go.
Good Luck!
Feb 11, 2009 | SanDisk Sansa c200 MP3 Player
USB not getting recognized
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Dec 31, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa fuze is not working
Hi and welcome to FixYa,
Appreciate the direct "Ask Me;.
Offhand, the message indicates that the Sansa is requesting that the internal storage be reformatted using the PC. This would require that the Fuze be connected to the PC through USB. Thereafter, the computer would recognize it as an external storage device. Steps required to format:
  • connect Sansa Fuse to USB of PC;
  • double click on "My Computer";
  • it would show probable as an "E";
  • right click on the "E" and click on "Format...";
  • a new window will pop up;
  • under the "File system" pls select FAT or FAT 32;
  • verify that "Quick Format" is un-checked;
  • click on Start button.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 21, 2008 | SanDisk Sansa Fuze MP3 Player
Sansa c240
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Cant load songs
Windows XP SP1
Intel Pentium class PC or higher
CD-ROM drive
TRANSFER MUSIC
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c200 MP3 Player Logo
121 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
