Question about Invacare Lightweight Tracer SX5 Wheelchair 18" with Flip Back Arms & Footrest
Changing the dual axle on an Invacare recliner to lower seat
My mother just received an Invacare SX5RC recliner from Hospice. I would like to lower the seat to floor height to 171/2 inches. It is now 2 inches higher which was fine until we put in her 2" seat cushion. On-line it says the chair is dual axle and can be lowered 2 inches. How do you do this? Hospice just has a warehouse of these chairs without any tech help. Thank you.
  • 40 Answers
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
Posted on Mar 30, 2009
How much a switch model MKVI 1089384?
Refer your inquiry to a Hoveround dealer and/or Hoveround
Oct 15, 2015 | NRS Hoveround MPV 4 - Hovaround Used...
The wrench symbol is flashing amber, chair won't move what is the problem?
The wrench means that something is wrong with the chair and it may be unsafe to operate. It needs to be checked out by a service man.
Aug 23, 2015 | Invacare Pronto M41 Power Wheelchair -...
My Invacare Wheelchair w/tilt & recline doesn't fully charge. I'm on the third new battery change & still same issue. Could it be my circuit board. Could it be me joy stick?
In any device that has a charging circuit that circuit can fail to charge batteries after a time. Ypu could have an electronics technician check what happens in the charging circuit. As you have changed three batteries the fault must lie elsewhere, as you have deduced.
Support Surface Resources
Support Surfaces
Jul 04, 2015 | Invacare Health & Beauty
My son has a invacare chair should go 6 mph but has slowed to a snails crawl. How Can I speed it back up?
The chair may be in what they call SLOW MODE or the batteries are weak. If you have powered seating on the chair the seat has sensors that make the chair drive slow or not drive at all when the seat is tilted or reclined or raised. A sensor can go bad or get out of position. The joystick could have different programming for different drive modes. Try changing drive modes.
Jun 11, 2014 | Invacare Supply Group Pronto M61 Standard...
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Rear wheels making a poping sound
Sounds like the rear axles are a little loose. More likely the rear wheel bearings that fit in the hub race of the wheel are worn out. There are 2 bearings per wheel or 4 total for the 2 rear wheels. They are available from The Aftermarket Group. com. To install, remove the wheel axles and pop out the bearings. Use a soft mallet to hammer in the new bearings. Do not overtighten the axles on assembly. The wheels should spin freely when the wheel is in the air. Hope this helps
Nov 02, 2010 | Invacare Supply Group Invacare IVC Tracer...
The passenger front seat will not recline - how can I fix
2010 Equinox drivers side won't recline.
Found the cable popped off recline mechanism.
Pulled back the lower seat panel near the recline lever after removing one torque screw located on said panel which is on the back of seat. Works great now. By the way, Freedom Chevrolet in San Antonio, Tx, without diagnosis, wanted to charge my girl friend $860 to replace the whole assembly.
Feb 10, 2010 | 2005 Chevrolet Equinox
How to change coil spring on 1994 ford ranger
RAISE AND SAFELY SUPPORT VECHICLE.PLACE A SUPPORT UNDER THE REAR AXLE.REMOVE NUTS AND BOLTS ATTACHING THE SHOCK ABSORBER TO THE RADIUS ARM.REMOVE THE NUT SECURING THE SPRING TO THE AXLE AND REMOVE THE RETAINER.SLOWLY LOWER THE AXLE TO RELIEVE THE SPRING TENSION.REMOVE THE SPRING BY ROTATING THE UPPER COIL OUT OF THE TABS IN THE UPPER SPRING SEAT - TO INSTALL.INSTALL. THE TOP OF THE SPRING IN THE UPPER SEAT.ROTATING INTO POSITION.RAISE THE AXLE UNTIL SPRING IS SEATED IN THE LOWER SPRING SEAT.INSTALL THE LOWER RETAINER AND TIGHTEN THE NUT TO 70 - 100 FT LBS .THEN CONNECT THE SHOCK ABSORBER TO THE RADIUS ARM AND LOWER THE VECHICLE.
Aug 01, 2009 | 1994 Ford Ranger Supercab
Invacare Lightweight Tracer SX5 Wheelchair 18" with Flip Back Arms & Footrest Logo
163 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Andrew Taylor
Andrew Taylor
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
