Question about Maytag MTB2656G Top Freezer Refrigerator
Two year old Maytag Fridge not cooling
Model MTB2656GE is not cooling. 2years old. light inside comes on so power is to the unit. Fans inside not coming on. Stuck in a defrost cycle? Don't know how to unstick it. Seems too new to have a major component go out. Are there fuses somewhere that could be out? Could there be a thermostat problem? Thanks for your time!
  • 883 Answers
Pull the power plug for 15 minutes, then plug back in...same problem? tried adjusting temperature control knob (thermostat)? if yes to both questions, freon has escaped out of loop or faulty thermostat. Attempt force start of compressor with jumper clips: pull the power plug then find the two wires into motor and apply 120 VAC from jumper clips. If it spins, then faulty thermostat.
Posted on Jun 18, 2007
SOURCE:
MY Frigidaire Refrigerator is 2 years old, the Refrigerator is not cold, but the freezer is working fine, what is common fix?
Most will tell you the freon is bad. but i have found in most cases the freezer works but fridge doesnt.. I have found the solution to be a bad cooling fan on the fridge it self. if the fan is not cooling the fridge will not cool. You could pull the fridge out and see if you can see the fan turn it on hi and when the fridge kicks in see if the fan or fans are working.. dust can cause them to slow or stop.
Jan 06, 2015 | Frigidaire Refrigerators
Replace compressor or buy new fridge
Check all else before condemning the compressor. Condenser clean, fans working, defrosted etc. Compressor change is expensive and the unit may be beyond economic repair if over a couple of years old. See how much a new one is before calling out service.
Apr 25, 2012 | Maytag Refrigerators
My refrigerator has a smell that it never had almost like plastic.it is about 10 years old
the smell on your fridge sounds to me like its leaking.inside your fridge is surrounded by a type of gas that helps to keep your foods cool.once the side walls of the fridge have been penatrated the gas leaks out. in my experiance the unit is unreparable and fit for the bin
Apr 23, 2011 | Maytag Refrigerators
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Samsung model RS2556SH, refrigerator
I have a Samsung fridge model no. RS2556sh. We lost power and when the power came back on the fridge did not. The LED is blinking in the top right corner and the lights or on inside the fridge but not cooling in either side. It doesn't sound like the compresser or any of the fans are coming on. So, what's wrong?
Mar 13, 2009 | Samsung RS2556 Side by Side Refrigerator
I have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not...
hi thanks forr the question so you cleand the coils inside the freezer and at the back by the compressor and was the compressor running . if it was and still not cooling you have a compressor problem
Sep 26, 2008 | Refrigerators
Side by Side Can't find model # Not cooling enough
I cleaned condenser coils with vacum, emptied the defrost tray and vacumed all the dust from the unit, unplugging first of course. Now it is working just fine. Thank you fixya for all your help and postings.
I still can't find the model number anyplace on the unit. This unit is only 2 1/2 year old but no model number to be found on the unit. But
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way [email protected]
Defrost system problem; Check back wall of freezer for frost buildup which indicates the defrost problem.
Jun 20, 2008 | Maytag MZD2766GES Side by Side...
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Maytag MTB2656G Top Freezer Refrigerator Logo
296 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
