Question about GE (PSS26MSRSS) Side by Side Refrigerator
No water not geting any water thru the door but it is still geting water to the ice maker
  • merrell53 Jan 17, 2009
    ice OK. No water through door. get water flow OK at disconect for door removal. There is a blockage in the water tube @ 3 to 4" in from were water normally comes out of dispenser. I suspect the line is frozen.
    I dodn't know how to thraw it other than doing a complete defrost of the freezer
    ice OK. No water through door. get water flow OK at disconect for door removal. There is a blockage in the water tube @ 3 to 4" in from were water normally comes out of dispenser (A small flexible tube only went in that far). I suspect the line is frozen. The freezer was all the way up to 9.
    I don't know how to thraw it other than doing a complete defrost of the freezer
    . I tried a blow dryer on the coils of plastic tubing on the fridge side.
It works now. I don't know if was turning down the freezer to #3 (its still 5 F)
or if it was running a blow dryer up the dispenser or poking a wire up the tube. it took a few hours though.
Posted on Jan 17, 2009
No ice, it has water on door but no ice.
There are two sides to a water control valve. The ice maker side and the water dispenser side. So what I am saying is the problem could be the ice maker side of the dual water control valve. Is there still old ice in the ice maker? If not then pour tap water into ice maker. If after the water freezes and then dumps the ice into the ice bin that will indicate a defective water control valve, If ice maker does nothing but hold old shrinking ice cubes this would mean you have a defective ice maker. Let me know your model number and I will look up the part numbers. I will be here should you have questions, Thanks Sea Breeze
Mar 11, 2013 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
How do you flush water thru the water filter of my refrigerator
ice maker does not come out water to water hose and ice maker on/off switch red light two times blinking how can i repair to ice maker?
Jan 21, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Not making Ice. Appears no water entering Ice making chamber even though water is at the door.
The water valve has two coils one for chilled water at the door and the other for the ice maker. Sounds as if the ice maker coil is bad. Hope this helps you to find the problem.
Apr 30, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The ice maker is not geting water to make ice but the water is coming from the door
Your fill tube may be clogged or iced up. You may have a faulty water valve.
Jan 26, 2011 | Refrigerators
I have model #TFX25PRYAWW. Ice maker is not filling with water. Water still operates through door dispenser.
NUMBER 800 is your water valve. It has 2 solenoids. One for water and one for ice. I suspect your ice solenoid is on the blink. It could also be dripping slowly like a faucet and clogging like a stalagmite the ice maker fill nozzle. The only other thing in the ice box that controls that water valve is the ice maker itself. if the water valve is ok then the ice maker ain't getting the power to that water valve solenoid.
Dec 17, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker isnt making ice
That could either be the ice maker OR the water valve. The ice maker calls for the water when needed. If the water valve is bad then you will have no water. I have a manual and a video showing how to quickly and simply test the ice maker HERE
Sep 04, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
uiouio67
May 24, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Icemaker stopped making ice
see if it geting water if not it is probley the water valve if it is getting water then see if it freezeing ice cubes if so and still not getting ice the it could be the heater on the ice maker and it needs to be replaced.......
Aug 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not geting to the ice cube maker, it is
Look inside the water tube to the icemaker. It may be frozen. If so, thaw it out.
If not frozen, replace the water valve.
Mar 19, 2009 | Refrigerators
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Brad Goodale
