Question about LaCie (300740) 160 GB Hard Drive
Can't Connect Usually I connect my external hard drive to my macintosh Powerbook G4 and within moments an icon appears on the desktop and I use it to access the drive. In the middle of using it recently, it froze up a little bit, and now when I connect the external hard drive to my computer I can see the blue light blinking and the hard drive working, however it does not appear on my desktop or the desktops of my friends with macs. I turned off my computer and the external hard drive for three or so hours and when I returned it worked momentarily but I accidentally disconnected it and now it does not work again. Please help me to get the hard drive to appear on my desktop! I am connecting it using Firewire. I also tried updating my software with LaCie update 1.4.2 to no avail. Thank you! Jesse
  • 39 Answers
Re: Can't Connect
Hi Jesse. Have you tried, or can you try the drive on another computer ? That's a good way to check if the drive itself is getting defective. I'd try that one first ! It could be also the firewire cable, have you tried another one ? Else, it could be the hard drive in the lacie inclosure that's getting weak (you might wanna backup your data if you ever get it to be recognized, if there's anything that's important on it), or the lacie enclosure's firewire controller that's doing freegames. I've seen such problems more than often, and if nothing has changed in your setup since it was working, i'm betting on the failed drive. They aren't that reliable as we know. Hope that helps a bit. Thanks! cheebster.
Posted on Jun 18, 2007
0 characters
3 Points
Well i bought my first hard drive(WD) yesterday 10-25-10 and when i plug it into my mac power book G4, its not recognized. I went to utilities to try to format it. I see the hitachi drive and the Macintosh...
if you are trying to install through usb then check if the usb you are using is working try to connect a flash drive on the same usb and try of use the other HD on that usb and see if it gets detected if no then uninstall the usb drivers from device manager and restart the system and it will work and it will get instaled automatically
Oct 26, 2010 | Western Digital My Book Essential 500GB...
IMac won't recognize firelite external disk
Try to connect it to another computer (Mac or PC).
Disasemble the case, and remove the disk-drive.
Connect the disk-drive as a "slave" in some other desktop computer, and see if the drive is "detected", and if your files/directories are visible.
Apr 16, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link:
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Oct 21, 2008 | Western Digital Passport WDXML800UE...
My powerbook g4 won't recognize my external hd or my web cam but it recognizes my ipod.
I am not really sure but i think the Camara and the External Hard Drive have to be compatible with Apple I think so you can use it. An IPOD is made by Apple so thats why your G4 recognizes it. I would just buy like a USB Drive. And also try to download the Drivers also and you can do that by google-ing it that sort of think. Anyways just use a windows based computer Bro its much more efficient. Let me know how it goes alright.
Oct 02, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Secure HD Login Problem
in applications there is one called utilities in this is one called disc utilities see if the drive shows up ? if it does try repairing permissions and verifying the disc.
Aug 28, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
500 GB WD external hard drive not mounting
Just go to the drive icon in the mycomputer and open the drive you can get the files no need to go the utility
Jul 23, 2008 | Hard Drives
LaCie (300740) 160 GB Hard Drive Logo
201 people viewed this question
Top LaCie Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a LaCie Hard Drive Expert? Answer questions, earn points and help others
