Question about Lexmark Z1420 Printer
Stops at 10% when setting up to pring
My lexmark1400 will say printing started and then stop at 10%. Could anyone tell me how to get this printer to print. Thnaks rdbug57@aol.com
Do you have McAfee Security? Fought with this issue for two weeks, Lexmark even sent another printer. Installed new RAM (thinking it might be not enough/bad RAM), uninstalled service pack 3, FINALLY got rid of all things McAfee and voila! We now can print.
If you don't have McAfee, check for other security programs that might be interfering. I even thought it might be a Microsoft update.
Good Luck!
Posted on Jan 23, 2009
My printer starts then stops at 10 % could help me please
Posted on Jul 06, 2009
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
NO how can I cancel a page being printed How to cancel pring
To cancel your print command press Stop/Reset or X button from your printer... it may work well..... thanks.
Aug 20, 2011 | HP Office Equipment & Supplies
How do I print configuration in Bizhub 250?
Touch utility button then on the touchscreen hit in the following order User Settings, printer settings, print reports, configuration page, and the start button
Oct 02, 2009 | Minolta bizhub 250 Black and White Copier
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
Gateway Computer will not send any document to any printer
ur default printer might be set to microsoft image printer...
go to control pannel, then go in printer & fax then right click on appropriate printer & click on set it as default printer...now try printing
Apr 10, 2009 | Gateway (4000635) Motherboard
Printing receipts on Omni 3200
This would be in the programming they have to use, the only option would be to change to another provider.
Jan 20, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
1320 not printing all the time
Your USB cord may be too long, or you have too many USB devices running. Try removing any other USB device, except the printer and do a test print.
Nov 17, 2008 | HP LaserJet 1320 Printer
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
Laser jet HP 2600n
Before you print, check the printer settings and see if it is set to choose paper automatically. If it is try manually setting it to the tray 1 you mentioned. This may stop the printer from checking every time it is grabbing paper. Also try keeping the other tray slightly open which may automatically tell the printer to look right away at the other tray.
Hope this helps!
May 01, 2008 | HP Color LaserJet 2600n Printer
Check paper size message even though paper size is correct
Make sure when you send the print job, that manual duplex options are NOT selected.
Jan 16, 2008 | Epson Aculaser C1100 Printer
Lexmark Z1420 Printer Logo
245 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
