Question about IBM ThinkPad T22 2647 Notebook
Getting hot underneth
I'm having trouble with the battery on the IBM thinkpad t22. For some reason it's not charging,eventhough the battery light is green and shows that it is fully charged. As a result as soon as the A/C adapter is disconnected it turns off. So it has to stay connected the whole time if not it shuts off.
I bought a second battery, charged it overnight, but I'm still having the same problem. The battery light is green, which means a fully charged battery, but it's not holding the charge. When i check the power source for the battery it reads that it is only 29%total battery power remaining. That's with the new battery and it connected to the A?C adapter.
Basically the batteries aren't charging. Could it be that both batteries are dead, even the new one? Or something else?
    Problem Solver:
  • 10 Answers
I have seen a similar issue with a Dell Inspirion 600m, the problem with that computer was the AC adaptor for what ever reason would only power the laptop but not charge the battery. I resolved the issue by replacing the AC adaptor, with a new adaptor from Dell and not a cheap after market one the problem went away and the batteries were charging.
Posted on Jan 16, 2009
  • 2,229 Answers
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
2 Suggested Answers
demiyan
  • 24 Answers
SOURCE: IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Posted on Sep 28, 2008
I was given ThinkPad 2647 T22 and it has been in it's case for 1 year. I plugged it into the AC adaptor and the green indicator light came on that the battery was charged after 5 hours. When I pushed the...
Remove the battery and try to power on without it. Replace the battery if the computer powers on. If not, the motherboard have to be repaired/replaced.
Aug 15, 2010 | IBM ThinkPad T22 2647 Notebook
Is IBM Thinkpad T22 equipped with WIFI & what's the USB port vers
IBM Thinkpad T22 doesn't have Wi-Fi adapter installed. you need a USB Wi-Fi adpater in other to have Wireless connection.
You can go for D-Link, 3COM,belkin USB Wi-Fi adapter. Make sure the USB Wi-Fi adapter support the Operating System you installed.
Good Luck.
Jan 08, 2010 | IBM ThinkPad T22 2647 Notebook
Can't power up. my IBM ThinkPad T22. I have the green light that indicates that it's charged up, however when I push the power button it just makes a flash and nothing happens.
If you only get a green light, try removing the battery first. If a laptop battery has gone bad, it will prevent a laptop from booting up.
Now, if removing the battery doesn't resolve your problem, check the laptop charger to make sure that the adapter has not malfunctioned.
If your fans are spinning, then the problem is probably the one listed below.
The transformer may not be converting the voltages properly.
Try these steps first. If it comes down to the internal transformer, then you have to contact IBM.
Aug 09, 2009 | IBM ThinkPad T22 2647 Notebook
My IBM Thinkpad T22's battery doesnt last. can i fix that?
Basically you need a new battery. Recharageable batteries have a finite number of charge and discharge cycles and they lose their full charge capacity as the get older. The batteries will have less capacity over time ie less available battery time, and when it is worn out, it won't charge at all.
May 15, 2009 | IBM ThinkPad T22 2647 Notebook
Battery Repair
Repairing a battery for a laptop is not done. They have a useful lifetime, like a car tire, and then they are replaced. The reason for this is the chemicals the battery contains, some dangerous, and the possibility for chemical or electrical harm to the owner and/or the laptop itself. The solution is to buy a new one. You are looking at around $30 to $70 for a battery. Shop around.
Apr 17, 2009 | IBM ThinkPad T22 Notebook
Ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Sounds expensive, I'm afraid!
Here is IBM'smag-glass_10x10.gif explanation of the error codes.
What your machine is telling you is that a chip on your Motherboard is faulty and the only way to repair it is a new system board.
It is probably worth finding out how much IBM would charge you to repair it but I very much doubt you'd get much change from £500.
Mar 25, 2009 | IBM ThinkPad T22 Laptop
Green battery charging light flashing and computer won't start
Have you tried removing the battery and replacing it again?
Oct 30, 2008 | IBM ThinkPad T22 2647 Notebook
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
IBM T22 Battery won't charge & is not detected
Take it to a very good technician who will open it up and check a dry joint in the charging system.  Sometimes if you donot attend to it quickly you may find your T22 refusing to power at all with the AC Adaptor.  Delicate soldering may solve your problem.  Power may not be getting to the charging circuit and the battery thus it is totaly discharged.
Oct 24, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
127 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
