Question about Kenmore 22622 Top Load Washer
Wont always spin with a medium to heavy load
If washing any heavy items like towels it won't spin. I have to restart the spin cycle and rearrange the load. Then manually hold the lid button and spinn the drum by hand to start it spinning. Light loads do fine.
  • 460 Answers
Seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Posted on May 09, 2009
The mashine doesn want to go on 1200rpm spin. It just spin at slowly. Model: Series 6 Varioperfect
Mine does this if the load is unbalanced, usually when it's got heavy items in it like bath towels, mats etc. I have to stop it, open the door, rearrange the items and start the spin again.
Sep 07, 2016 | Bosch Washing Machines
Can't stop cycle
You probably have some other issue with the machine if it won't stop, but the machine may also not be spinning the mat out because the load is unbalanced. If you put it in on spin only, watch to see if it actually spins up to speed or not. You will see it rotate the drum back and forth a couple of times - it is sensing the weight of the load and trying to balance it. I the machine can't balance it, it will never spin up to max speed. If this happens, put a few other items in the washer with the heavy item (they need to be of similar weight - like some towels or a heavy jacket or something) and try again. Good Luck
Apr 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
The center spindle intermittantly stops spinning on heavy loads
The agitator is probably stripped and will need replacing.
Jul 05, 2009 | Washing Machines
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
My kenmore elite smartwash quiet pak 9 he 4t seems to be off
have you tried lower spin speeds? I found with heavy items such as towels and jeans it is best to lower the spin speed. also washing like heavy items on a certain wash cycle is best - i.e. towels on bluky/bedding.
hope that helps.
Apr 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 22622 Top Load Washer Logo
189 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
