Question about Black & Decker CTO6300 Toaster Oven with Convection Cooking
Half working hi my oven only the top elements work bottom 2 quit working a few days ago tried to cook a pizza only the to browned please help Coops40
  • 2 more comments
  • Anonymous Nov 06, 2007
    SAme problem.. Don't know how to fix.. Ruined pizza.
  • unl67volvo Feb 24, 2008
    I too lost my lower elements a couple weeks ago. The front one had a 'hot-glow' spot one day (perhaps from something that dripped on it?) and then the lower elements stopped working. I assume all I need to do is fine one good element to swap for the bad one and I'll be back in business. Now, it's just a matter of finding that part! Anyone have any ideas? I'm thinking of posting in Craigslist about it, and emailing others w/ similar problems or who say their oven died (hoping they still have it and would be willing to part it out (preferable) or part it out just for the element(s)). I'd rather try and fix it than go out and buy a whole new toaster oven since this is less than 2 years old!
  • Anonymous Apr 05, 2009
    Only the top two elements work. This was an expensive unit. I would like to know how to fix it but this website is complex to see how to find the solutions. ****!
  • Anonymous Mar 17, 2014
    Model# GRPWS-2424dD
    When I turn the warmer on top tray comes on and after reaching the temp of 150 it quits working. Bottom tray is working fine
See my above comment for suggestions on how to fix it...
Posted on Feb 24, 2008
Bravetti toaster oven
Not enough voltage getting to the heating elements. Look at the thermostat or the control board for the problem
Jul 28, 2017 | Toaster Ovens
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
Pizza is soggy
Not working properly accordiing to the manufacturer.  Not fixable.
Jan 27, 2009 | Toastmaster TOV200 Toaster Oven with...
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Lower Heating element will not turn on
take notice of the local repairers
if they say parts are hard to come by , a DIY will have even more trouble
junk it and get a new one
Nov 24, 2017 | DeLonghi EO1258 - Stainless Steel Toaster...
Black & Decker CTO6300 Toaster Oven with Convection Cooking Logo
488 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
