Question about ASUS P4B266-C (P4B266-C WA) Motherboard
I tried to install a new motherboard but it didn't work
First I tried to install a bigger memory card, but when I turned it on, it started beeping. I checked all the other cards (video, sound) and it continue beeping. As I had another motherboard (asus p4b266c) I replaced. After that it didn't work at all.
Thanks for your time
Sylvia
    Scholar:
  • 62 Answers
Your bios needed to be set with the correct memory speed on your old motherboard or it did not support the memory you added or it was in the wrong memory slot or size. The beeping was telling you it was a memory error. I need more info such as processor and memory speed and type to help. What is your old motherboard? It sound like Bios settings but I need to make sure the memory and processor will work with *********** board.
Posted on Jan 16, 2009
Three beeps at interval no thing on monitor. what can i do? ihad just loaded a new os and was working fine.i shut down and change memory stick.turn back on and hear these beeps.re-install origin memory...
Beeps are mainly caused by bad, dusty memory module or the port it is connected to. However, since you have tried changing it with a working one and i suppose you already clean it that's fine. One more hardware which causes beeps is the video card. If you have a video card installed, it may be moved when you change the memory module. I suggest you try to reseat the video card as well..
Hope that works
Feb 13, 2011 | Asrock K7S41GX Motherboard
I get continious beeping in my computer with no display
No beeps Short, no power, bad CPU or motherboard, or the CPU is not installed properly. One long beep, then two short beeps Video problem Continuous hi-lo beeps CPU overheating Repeated long beeps Memory error All other beeps Memory related error
If you are getting hi lo beeps, refit CPU and heatsink
If continuous long beeps, check memory is seated correctly, if more than 1 stick, try each one on its own, 1 may be faulty, or incompatable
Aug 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
K9VGM-V beeps.
sounds like a faulty memory module............replace and try again
Aug 01, 2009 | MSI K9VGM-V Motherboard
Pc keeps beeping 3 times and nothing on the moniter
remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
Step3
One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
Step4
Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
thanks.
Jul 11, 2009 | Asrock 775i65G Motherboard
I tried to install a new motherboard, and it is not working at al
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us This is a link to the new board you installed good luck send me more info and I WILL HELP MORE IF I can. Good luck.
Jan 16, 2009 | ASUS P4B266-C (P4B266-C WA) Motherboard
Motherboard problem
These more up to date cards have a special PCI-E connector actually on the card which you have to connect to your psu too.
It shouldnt beep if theres no problems
If you cant get video or anything , make sure that the cardrs power conenctor is plugged into the psu
Jan 07, 2009 | Computers & Internet
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
Not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Oct 21, 2007 | Intel Motherboard
ASUS P4B266-C (P4B266-C WA) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
