Question about Procom ML300EBC Heater
Pilot goes out with fire place
The fire place runs fine. When it gets to tempeture the flame goes out. The problem is the pilot goes out with it.
  • Procom Master
  • 3,253 Answers
Is there a power phile on the fire place
Posted on Jan 17, 2009
Regency fire place will not stay lite got pilot going fire stays on 1 min then goes off . checked all pipes they are all clear.
Clean pilot so its a strong blue flame check thermocouple is not brunt out . check thermopile is giving out 600 millivolt's.
Oct 04, 2016 | Grilling
Why does the flame shut off before a hot to warm temperature can be achieved
I would question the Thermo couple. It pretty much runs the whole show. Inexpensive quick fix. It's the small tubing that is connected to the gas valve. The other end is a bulb that sits over the pilot flame.. Remove the old and match it up at the hardware store. Install new coupler ensuring bulb is directly over the pilot flame Common iten. The thermocoupler alks to the gas valve. If the pilot flame extinguishes (goes out) the bulb cools and shuts down the gas valve so the pilot gas feed doesn't permit raw gas to accumulate, avoiding the need emergency Services. . You will not get the heater to fire until the bulb is good and hot. The red push button ,when depressed will allow the pilot flame to be lit. Hold it down until the heater fires, indicating the T-coupler has reached its operating temp.Good Luck-Ned
Sep 10, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
The pilot light will not stay on for more than 5min. If I light the fire when its on,it just goes out. The fire is a Fusion 2/7
I assume this is a gas log? If so, you have dust in your pilot assembly. Turn everything off and let it cool. Note the opening where the pilot flames burns. Use the wand from your vacuum cleaner and place it over the opening for the pilot flame. Gently tap the side of the pilot assembly while holdign the vacuum above the opening. This will lift the minute dust particles out and allow the flame to burn nice and blue again. These logs have Oxygen Depletion Valves on them. The pilots are very sensitive to dust.
Jan 18, 2011 | Heating & Cooling
The pilot light only partially lights and goes out when turn knob to wide open position.
i'm guessing here it may be that the pilot from where the flame comes from may have a spider web or something similar in it when i did my training on servicing some certain heaters the instructor told me about this and i thought it was a big joke until it happened to me and yes did find a very fine silky web inside pilot so when flame came out it was very yellow and went up in the air like a cigerettte lighter flame, not a blue horizontal flame like it should be so it didn't make any contact on thermocouple and wouldn't change no matter how much i adjusted i was going to order new pilot assembly when i remebered about what i was told and took pilot out to find a spider web in the pilot, this usaully happens over summer or warmer periods where spider gets into fire box then crawls into pilot as it is a safe place till you use the gas and kill the spider but leave a silky web inside pilot tube atop of the bonnet for pilot!
Nov 24, 2010 | DCS PHFS Phoenix III Outdoor Patio Heater
Gordon-Ray overhead radiant heater that won't go into high fire
Is this a standing pilot unit. So when it goes into high
fire is it just actually going from pilot to burner on ?
If this is the case and the burner shuts down, then
it is the flame sensor.
If it is two stage heat and 1st stage is fine, then when
second stage comes on and goes out, I would be looking at the supply of gas.
Jan 24, 2010 | Heating & Cooling
I have Rudd hot air gas furnace. The ignitor sparks and lights the fire but as soon as the ignitor goes off the fire goes out, flame light doesn't go on. What could be the cause?
Hi, Check the flame sensor next to the pilot. It should be a ceramic rod with a metal tip that rests in the pilot flame. It may be dirty. Clean the tip with steel wool real good and make sure it is in the pilot flame good. This will cause that condition to happen. If this doesn't take care of it, get back to me and we will go from there. Should solve you're problem. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Ruud UBHC Air Conditioner
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
We dont think our cylinder is on we have just moved in and have no hot water
The question is? I'll assume you cylinder is the water heater, right?
On the heater (water) you will find or see the red controls and a sheet metal cover over a hole. Remove the cover and this is where you light the pilot light. Press down on the red dial and turn it to pilot. In that position you will be able to press the red button . Geyt a long match or bbq lighter, then, holding down the red button dow for a minute or so and place a match or lighter into yhe area where the lines go The flame will catch the gas and lite the pilot if yo simply move your glame around. When the flame catch on the pilot, continue holding the button down for sveral minutes until the buld the flame isheating gets hot. Then release the buton and turn the main dial to on. The main burner should fire up. If not, and the pilot goes out, repeat the process. The bulb in the pilot flame is a thermocoupler that shuts all gas off if it doesn't detect a pilot flame, so hold the button down longer. If the pilot goes out when you release the button, The thermocoupler is no good and needs replacing. Good Luck_Ned_
Oct 31, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Flame goes out Monessen Ventless fire place Model DLX24.
take a needle and put it into the end of the gas pilot hole. Wiggle it around in there, it just might have dust build up in there. Hope this helps ya.
Jan 17, 2009 | Stoves Monessen Variable Thermostat...
Procom ML300EBC Heater Logo
108 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
