Question about Mitsubishi WD-60735 Projection Television
Mitsubishi DLP WD-60735 Keeps Shutting Down After 20-30 Minutes
I purchased Mits WD-60735 on 12/26/2008. After about two weeks, the TV suddently shut off by itself and the lamp light came on and was red. According to the manual, I need a new lamp. Had a tech come out today who was confident that replacing the bulb would fix it. After 10 minutes, the set shut off again and the lamp light came up red. Luckily, the tech saw the whole thing. He stated that the fans appeared to all be working. His theory is that something in the power supply is triggering the TV to shut off. If that is the case, why does the lamp light come on red? In any event, they are coming tomorrow to pick up the set and take it to the shop for repair. According to the back of the TV, the set was assembled in December 2008. I have read all the information regarding the many problems with the previous Mits tvs. There seems to be very little about the WD-60735. I have seen some data about the color wheel on the WD-60735. Has anyone seen this before? Is anyone having the same problem I am? If so, did you get your set fixed? If so, how?
  • 2 more comments
  • Anonymous Jan 30, 2009
    MY TV IS JUST OUT OF THE BOX PLUGGED IT UP 20 TO 30 MINS
    TURNS ITS SELF OFF MY LIGHT IS GREEN AND FLASHES CANT TURN IT BACK ON UNTIL THE LIGHT STOPS FLASHING TURN THE TV BACK ON AND IT DOES THE SAME THING OVER AGAIN HAVE DONE EVERY THING THE BOOK SAYS AND NOTHING WORKS EVEN CALLED THE FACTORY THEY DONT KNOW ANYTHING
  • dntampa71 Feb 15, 2009
    unfortunately I just purchased my tv in Jan 09 assembly date was also Dec 08. Just tonight the tv just started turning itself off for no reason, it will stay on for 4-5 seconds than shut off again? I was trying to change inout to dvd player when suddenly "caput"... tried system reset button as manual suggests but to no avail. Help!!
  • lhagin Apr 18, 2009
    We bought our tv a week ago. We have not had it on very many hours. Last night, while watching a movie, the tv shut off. The light went to red. I tried the system reset and unplugging the tv. Once I turn the set back on, I hear the audio - but, no picture. After a couple of minutes, the set turns off by itself.
  • Renee Lopez
    Renee Lopez Oct 09, 2015
    That's wa
    Hats yapping with my tv any help please email me lopezr67@yahoo.com my tv turns right back on help
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
  • 38 Answers
SOURCE: mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Posted on Dec 24, 2008
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Posted on Jan 11, 2009
Mitsubishi dlp
which of the three lights is flashing red?Let me know and I will assist you with the issue.
Mar 21, 2013 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
My TV will not turn on. I just replaced the tv lamp 2 weeks ago. Help!!
did you use original Mits Lamp or a generic?? most mits DLP tvs wont run long or at all with generic lamps
Sep 30, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
TV is warming up slowly
Based on model number indicated and fact it is not shutting down it most likely is the lamp reaching the end of its 2000 hour life.
Original lamps from Mitsubishi last longer than "generic" ones that often have half the life and are not as bright.
Jun 11, 2012 | Mitsubishi WD-60735 Projection Television
My tv mitsubishi wd-60735 turns on for about 2 min. then shuts off and red lamp light turns on,,,The lamp is only 3 months old.. Do I just need to replace bulb again or is it something else???
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Jul 20, 2011 | Mitsubishi WD-60735 Projection Television
My WD- 60735 mitsubishi tv will come on and work properly for about 5-10 mins then shut its self off. A orange light will flash 1-3 times then go green and blink for a period of time, what is the prblem?
Count the number of flashes of the green light and make note if there is a sequence. Google WD-60735 blink codes. This will send you to a number of links to choose from. The blink code will tell you what is wrong with your tv.
May 08, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WD-60735 has verticle bars with broken image. Its like looking through a kaleidoscope. The only way to fix it is to let the tv power off, then cut on again.
This is your digital module going bad. The only way to repair this is to send your Light Engine Cube Assembly to Mitsubishi to be refurbished. I believe they charge the consumer 300.00 to rebuild. I have seen 3 just this past week. All DLP sets are failing at a high rate now.
Dec 20, 2010 | Mitsubishi WD-60735 Projection Television
I have a 60in Mitsubishi tv that keeps shutting off and the light on the front goes from green to to red or orange blinking. We can only watch tv for a minutes at a time and it keeps happening. Really...
It's too hot. Get out your owners manual or download one and it will tell you how to remove the bulb housing. Clean it and re-install. Make sure the TV can get sufficient ariflow around it.
Dec 09, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi WD-60735 Projection Television Logo
2,627 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
